Noob enthusiast looking for answers
1.5K views 13 replies 5 participants last post by  blackwabbit
I have been searching the threads for a couple of days before I question away at the veterans (to save myself from any embarrassment). Alas, I have not prevailed in my search. I have an 03 passat 4 motion (130000 miles) that I have had no issues with up until now. Recently, I have noticed that the RPM's kick up on the car when I am driving on an uphill incline or even on a flat road. This causes a slight kick in the car that I can feel and visually see via the RPM's revving up slightly and then back down. It does this when I have the gas pedal depressed but am at a constant speed. In other words, when I am not giving it gas to speed up. It happens about every 5 or so seconds when I am in a situation such as the described. I am by no means a mechanic and have very limited knowledge of the operations in general. Just curious to get opinions from the people with the know how. The engine light had been on for several months before this started (started about a week ago), I took it to advance, got a reading, catalytic convertor error. Any thought on the cause? Any help would be much appreciated. :confused:
Just FYI, try to provide an overview of your question in the post's title, such as "unusual RPM increase at constant throttle". Also, mentioning what transmission and engine you have is always helpful. Assuming that your trans is an auto, the best advice is to get the car scanned with VAG-COM or VCDS software, and especially the transmission controller, otherwise known as the TCM. Steve may be correct about a TC clutch being what you feel. When engaged, the TC clutch makes the transmission behave like a manual transmission, so that if you let up on the gas, the engine speed is directly related to the car's speed. When the TC clutch is not engaged, letting up on the gas results in an immediate drop in RPMs, and applying throttle causes an immediate rise in RPM.
#10 ·
MAF stands for Mass AirFlow Sensor. The engine computer and the transmission computer use data from that sensor to make all sorts of decisions. One of them is estimating torque load. Decisions about when and how shifts are performed (including down-shifting) are based on torque load. If the MAF is bad and telling the computers that the engine is working harder then it really is, the computers may decide to downshift (or unlock the converter) to give the engine more leverage.
Don't go replacing the MAF unless you have diagnostic evidence that it is bad. The above is just one of many things that could cause the symptoms you're describing.
