Hello friends,
2003 Passat 1.8T automatic, stock. Purchased cheap with big engine problems. Replaced timing belt, chain tensioner, and oil pump. Ran great for two days, then started to run rough. Vag-Com reported P0300 random misfire multiple cylinders, and P0303 misfire cylinder 3, intermittent high level.
I swapped coils 2 and 3, cleared codes, and test drove. Ran great for 15 minutes, then rough again. Vag-Com gave P0300 and P0303. So the coils are OK. Swapped injectors 2 and 3, cleared codes, and test drove. Same crap, ran good for 15 minutes, then rough. Vag-Com gave P0300 and P0303. So the injectors are OK.
Compression test gives about 155 PSI on all cylinders. Ran a smoke test, and the vacuum lines are all good.
It only happens when it's fully hot. So lastly I pulled the #3 coil and grounded it on the engine, and started it up cold. #3 sparking great cold. Put coil back in, and took it for a test drive, and it ran great for 15 minutes, then rough again. While it was still hot I pulled the #3 coil again and grounded it on the engine. No spark!
So, this has to be the wiring or connector to the #3 coil, right? Since it doesn't move when the coils are swapped? But how can heat cause this?
Any thoughts?
Thanks,
Keen
Any thoughts?
Thanks,
Keen
