Low power to subwoofer. Weak ground issue?
4.5K views 14 replies 4 participants last post by  30vVT
This is a weird one. I disconnected my box in order to pick my bike up at the repair shop and fit into my trunk. After I hooked everything back up though without any changes, the sub only runs 25% as hard as before with the gain on the amp all the way up (only had it turned up 50% when working properly). Only thing I changed was moving the sub box to the right in my trunk to accomodate my bike. Messing with the sub pre out volume from the HU only has a minimal effect compared to before. Only thing I can see is my ground is connected to one of the 3 screws holding the fuel pump cover down and it looks like the ground melted some of the foam attached to the car surrounding this cover. The insulation still looks good though despite being brown at this point. All fuses are intact and look fine. Is it possible to have a weak ground which is good enough to keep the amp on at all times yet not enough power to fully power the sub? Thanks for any insight!
Bill
quality_sound said:
you didn't disconnect the speaker wire from the amp did you? you probably shorted the speaker wires together and damages the amp's outputs.
I taped one of the speaker output wires so I don't think thats it. How should I test the outputs with a multimeter?
Thanks for the replies
it still could be, if that other un-taped speaker lead ended up touching a ground.
if you suspect a grounding problem, then check/fix it.
other than that, there is little you can do with just a meter to test it.
you're right, I'm just afraid that I killed my amp and am somehow trying to talk myself out of the possibility of needing a new one. I'll run a new ground and see what happens. Thanks for the help thus far.
#11 ·
I hate searching and finding unresolved threads so I figured I'd let you guys know that the solution to my issue was indeed a bad ground. Apparently it is possible to have enough power to turn the amp on but not hit the subs hard.
#13 ·
I took the ground off, created new crush ring terminals that were super tight using a hammer ( I have 4 guage cable), and changed the ground point from the fuel pump cover screw to the allen bolts which fasten the 60/40 seats to the same pivoting bracket in the middle of the back seat. Its the only part I changed or replaced so by process of elimination, it had to be it. I did also take my amp apart to see if anything looked charred or busted, ran continuity tests from the ground/power connections to both the outputs and the circuit was good so I assumed that the amp at least could make a circuit. FWIW I have a Pioneer GM-5000T bridged to a single 10" MTX Thunder 8000.
#15 ·
If you fold the seats down and look at the bracket that holds the backs of the seats together, you'll see 2 black allen bolts on the back of the bracket facing the back of the trunk. You can connect to these without the seats kinking or bending the ground connection if you repeatedly have to pull you seats up and down for cargo.
