I just quadrupled the range on my key FOB!
36K views 79 replies 51 participants last post by  Rob.Achmann
So the only thing I was disappointed with when I got my car was the range of the keyless entry. I had to be within 25 ft. of my car for it to work, also my 2000 Jetta had about double the range. Well, I fixed that today. I got the idea from an A4 TSB that fixed a routing problem with the security antenna. After failing to find info online for this task on my car, I went to work to figure it out myself.
First I had to find the antenna, which turns out to be under the right-side A-pillar trim panel. The problem with this position is that is near metal so it doesn't have good reception. For those who don't know, the antenna wire is nothing but a length of coaxial cable to shield it from interference. The antenna itself is just a length of the cable with the outer insulation and shielding wire removed. The length of this section is important as it is tuned to the frequency of the transmitter. I'll get to the length in a bit.
I then traced it back to its source. The security module is located in a plastic box under the driver's feet. To get to it I had to remove the dead pedal, cowl trim panel and the front of the driver scuff plate. Use caution when removing these panels as they are easily damaged. If you have problems with any of them, let me know and I'll explain the specifics of removing them. Once they are removed, I peeled up the carpet to partially expose the security module. This can be removed by lifting up the forward edge and sliding the whole box forward about an inch to free a clip.
Once it is out and dangling by the wiring, I pushed in the two tabs and hinged the top open. Inside there is another box with two connectors. This box will come free by pushing the forward side tab and lifting the box out.
This is the point where I pulled the negative battery terminal. I'm not sure that there would be any problems, but I didn't want to chance it.
The smaller connector (tan) has the antenna wire in it, actually both the antenna and the coax shielding wire. You can tell which one is the antenna by looking for the wire with clear insulation. If you trace this one up you can see where it joins another wire, this is the shielding. Now you can tell which pins these wires connect to in the security module. I looked inside the connector portion of the security module and found mine corresponded to pins 7 and 10, 3rd and fourth over from the left on the top row. I then pulled the cover off the security module. The cover is held down by four tabs that can easily be disengaged. I traced the pins to where they connect to the computer board. To these two pins, I soldered the ends of a 12 ft piece of antenna extension wire I got from Murray's Auto Parts (chain parts store similar to pep boys or auto zone). I had clipped off one end of the wire and separated the shielding wire from the inner insulated wire. The inner wire (antenna) was soldered to antenna wire pin on the backside of the computer board and the shielding to the shielding pin next to it. Any exposed portions were covered with electrical tape to protect the system.
I ended up having to put a notch in the top of the security module box to allow the new antenna out. BTW, I decided to leave the old antenna, as didn't seem like having two would be a problem. I then reinstalled the security module in the hinged box and ran the new antenna between the existing wiring grommet and where the top would close on it. I closed the lid and put it back under the carpet, careful to slide it under the retaining hook before lowering the forward edge.
I then ran the wire (end connector and all) rearward under the scuff plate, under the edge of the rear seat and behind the left side trunk trim. I then took out the rear tail light by removing the three nuts on the inside side of the tail light. I ran the wire through this opening.
The reason I left the connector on was in case the wire was not long enough to get here. It certainly was tight. You may do a better or worse job running the wire and may have extra or not enough. If it was not enough, I would have gotten another short length and the connector would have made this easy. However, for me, the longest piece I could get (again 12 ft) turned out to be perfect.
I then made the antenna by cutting off the connector and removing the outer insulation from the end to 8.5 inches from the end (very important to match the length of the OEM antenna), I also cut away the shielding wire from this section. I was left with 8.5 inches of semi-transparent insulated wire. I wrapped the end of the wire and the interface between the shielded and unshielded sections with electrical tape to keep out the elements and keep it from grounding to the body. I then attached the antenna to the backside of the plastic part of the bumper, away from the metal of the body and reinstalled the tail light (careful that the antenna wire was on lower portion of the tail light opening and would be sealed well by the foam gasket on the tail light).
Everything was re-installed and I tested the system. I found that I could get about 400 ft from my car and the key FOB still worked! I know that I may not have explained perfectly and I apologize, but I haven't got a digital camera to make this easier. If you've got questions, please ask. Good Luck.
Re: I just quadrupled the range on my key FOB! (NVMYB5)
You want ot really increase the range without ever having the open the fob and jimmying with it.....put the fob in your mouth and push the button...it seems that a human head is a natural attenna..
I have unlock my door from at least a football field away by doing this....
But the question is why would you want to open your doors from 400ft away.....
<![CDATA[You want ot really increase the range without ever having the open the fob and jimmying with it.....put the fob in your mouth and push the button...it seems that a human head is a natural attenna..
[Modified by MeinPassat, 2:19 PM 8/11/2002]
Re: I just quadrupled the range on my key FOB! (Rice Boy)
It would do about 50 ft with it under my chin, and now 400 without being under my chin. I guess I multiplied the range by roughly 8, not 4.
anyone worried about cancer from the beam near theur mouth?
<![CDATA[anyone worried about cancer from the beam near theur mouth?
[Modified by Anthracite, 11:33 PM 8/11/2002]
#6 ·
Re: I just quadrupled the range on my key FOB! (MeinPassat)
<BLOCKQUOTE>quote:<HR>You want ot really increase the range without ever having the open the fob and jimmying with it.....put the fob in your mouth and push the button...it seems that a human head is a natural attenna..
[Modified by MeinPassat, 2:19 PM 8/11/2002]<HR></BLOCKQUOTE>
I wouldn't want to open my doors from that far away, but I sure would want to use my Alien remote to rollup my vented windows from inside my office when a t-storm approaches. Actually happened to me a couple weeks ago.
Very cool mod, good work!
<![CDATA[<BLOCKQUOTE>quote:<HR>You want ot really increase the range without ever having the open the fob and jimmying with it.....put the fob in your mouth and push the button...it seems that a human head is a natural attenna..
[Modified by jwil, 5:57 PM 8/11/2002]
Just one problem with the whole range thing....
The doors automatically relock after only a few seconds. Unless you are a good sprinter you'd never make it there in time to open the door. Plus you'd probably swallow the key if you were using the mouth method.
#10 ·
Re: I just quadrupled the range on my key FOB! (Fog42)
Seems like a lot of work just to avoid having to press a butten when you're within 50 ft. Also the head things is a great feature.
Remember, the doors will re-lock themselves once you've unlocked but have failed to open a door within a minute. Unless a pack of wild dogs were chasing you, the doors would probably reclose themselves by the time you walked to your car.
#11 ·
Re: I just quadrupled the range on my key FOB! (BoeserBlick)
Apparently no one has ever had a problem finding their car in the sea of cars.
#80 ·
Car-Finding super powers or not, when it’s raining, my kids always beat me to the car. At the mall, in a parking spot 4 light years from the mall entrance, I’d like to open the car doors for my fast footed spawn (evil that day, or not) to help them get out of the rain. Great job on the antenna!
#14 ·
On my car, the panic button doesn't always unlock the door, and I'm impressed by your car locating abilities. Small parking lots? I guess size doesn't really matter.
#17 ·
Not to sound like a prick...which it will sound like I'm a prick...but I aways where the B5 is parked...in fact I don't think I have ever "lost" my car in a parking lot, big or small....
It's what Fighter Pilots call SA, Situational Awareness....knowing at times who, what, when, where and why......helps in driving also...
I can agree with the whole "where'd I park the damn car" thing. Picture this:
You just stepped off a redeye from some city, after a week of meetings, customer appointments, long days, and longer nights. It's 4:30am, you're jet lagged, and have just walked from the farthest terminal in the airport to the six level parking garage.....Where did you park? Press...beep...press...beep...there's my baby.
I'm doing exactly that for two consecutive weeks this month.
#19 ·
Cullen,
Nice work. The range of our remotes do suck. And if you do have an AlienTech Remote, this WOULD come in handy.
Imagine the distance he could get if he put the remote under his chin now!!!
I many many times forget if I locked my car or not. I also live in a rather large house, and instead of running back into the house to get my keys to unlock my car door (habit that I always lock my car whenever I exit my car), then I can just use the intercomm and have someone unlock it for me! (won't reach from my room)
This mod isn't
or useless
if you think about it.
Thanks for the post
#20 ·
Re: I just quadrupled the range on my key FOB! (mistertam)
I've been watching this site for a while, and it can get pretty rediculous sometimes. This surprises me. I think this is a great mod. I don't understand why people have such a problem with this inovative mod. My car doesn't respond to the remote until I'm a couple of car lengths from it, even with the head trick. And this is how it has been since I got the car at the dealer. I've even changed the battery and had no luck. I've been looking for a way to increase the range, and here it is. I say thanks Cullen. I'll be doing this tomorrow. And that one day when my Situational Analysis fails, I've got a back up plan... Just like the fighter pilots have...
#21 ·
Re: I just quadrupled the range on my key FOB! (Shamus)
I didnt say I thought it was useless. I'm just saying it seems like a lot of work for something that I persoanlly think I wouldn't use much. Whether I click it from 400 feet or from 2 feet, its still does the same thing and I always know where I park. But thats just me... I like to know exactly where I parke my baby. To each his own right!
for your ingenuity.
Now a mod that would open and close the door for me without me having to even touch the door would be a cool mod for the couch potato in all of us... "KIT, pick me up in front of the mall! I can't find you."
#23 ·
Really cool! But wouldn't it have been easier to just move the existing antenna to a better location? How did you find out where the antenna was? How hard it it to get to the existing antenna?
#25 ·
Great Mod!! I hate the range of the remote on our cars. I have the Alientech and I am always trying to rool down the windows when I am aprroching the car. ( To vent out the heat) but its no good because the remote doesn't work untill I am within 50 feet of the car.
#26 ·
NVMYB5, great work
My previous car has excellent range of at least 100 ft, and I was disappointed at the range on my new B5.5. Which sometime I have to be within a car length to open the trunk.
I have a detached garage, and I sometime need to either open or lock the car from inside the kitchen. The range on my B5.5 FOB is not adequate for me to do so at the moment. I will definitely try this mod, and from what I see the mod is probably simpler than your lengthy worded explanation
You wouldn't happenned to be a RF Engineer would you ?
I think some digi pics coupled with a few simply worded instructions would draw less question & criticism. With a mod that one can do from the comfort of one's kitchen table, and not having to crawl into the engine bay. I am sure many of the B5 members will attempt this mod themselves. Again, great innovative work !
