How to install a blow off valve...
4.3K views 3 replies 4 participants last post by  ONE8T
Im having a lot of problems installing my new blow off valve. Im trying to figure out where the factory bypass valve is. If anyone can provide me with a diagram, it would be much appreciated.
Thank you
#2 ·
Let me give this a try:
1. You don't want to install a blow-off valve, you want a diverter valve which sends the air back into the turbo inlet. A blow-off valve will give you a MIL.
2. You can find the DV below and in front of the turbo, it's attached to the large hose going from the compressor to the pipe under the radiator and to the little vacuum hose going across the front of the engine.
Right?
/Patrik
wildinout29 said:
try turbosmart 50/50, i just heard it on my friends jetta and it sounds insane, no cels either
He may have no CEL's, but he's still running rich. I'll bet if you check his block 032 mult fuel trims he's running between -10 and -20%.
