How to get off B5.5 power steering fluid reservoir cover?
7.6K views 8 replies 5 participants last post by  VAGguy
need a bit more clearance to change driver side low bean bulb. trying to get the power steering reservoir cover off to gain a bit more clearance.
unlike B5, where the cover is small and you can easily yank it out.
In B5.5, the black cover is larger, and I just could not figure out how it is attached and how to get it out.
#2 ·
The cover has two integral plastic clips molded into the bottom side which affix to the metal frame underneath. All you have to do is pull the two tabs slightly outwards away from the metal frame and lift it up. Be careful not to pull the clips too far as they are plastic.
You have to pull off the rear taillight assembly on a B6 A4 to change bulbs as well. It's only one bolt though and it comes right off.
