Help Me Obi-Wan Passat Owners...You're My Only Hope.
1.7K views 19 replies 6 participants last post by  Kinsella5
First off a big thank you to everyone who helped me earlier this year with some issues concerning my car. For the record it is a 2000 Passat 4-Motion wagon, 169,000 miles, original owner. It's that time again where I ask for help because I am a complete loss as to what these issues are and seeing that I am probably one of the most least knowledge people on this site I figure I would ask you all. Overall the car has been fine, but a few problems have cropped up recently so here goes. The last time I had any work done on my car was back in February when I had new oil cooler hoses on and did a heater core flush. Since then the car has been fine up until recently.....
Problem #1: Around the end of June I was driving along when I started hearing a flapping sound. I was on a side street and going about 30 mph and the sound only occurred when I had my foot on the accelerator pedal. The sound reminded me of when I was a kid putting baseball cards in the spokes of my bicycle tires with a clothes pin, but not as loud. I could hear the sound bounce off the walls or trees as I drove by, hearing it slightly at lesser speeds and more so when I would get to 30-45mph. I thought perhaps I had driven over a plastic bag and it was flapping underneath. The next day the sound was gone and stayed gone for about two weeks or so when it returned. It really doesn't depend on anything meaning it has done it in the morning, or sometimes the afternoon, and even sometimes in the evening. For the record it's not the warping sound from a sunroof open when you have your windows up, nor is it related to the plastic skid plate because my car hasn't had one in several years. Sometimes I will drive days and the sound won't occur, other times it will do it, I will get to where I am going, turn the car off, and then when I come back and restart my car it doesn't make the sound. Basically it's all completely random. No check engine lights on the dash, I even had a local shop plug the code reader device in and no error codes popped up. My local oil change place knows me quite well and they checked all the fittings around the exhaust system and all were tight, intact, and not cracked. Has anyone experienced this random "flapping" sound and is so what was it? Or any suggestions what it might be?
Problem #2: Sometimes when I turn my car on, I noticed a bunch of black letters on the Climate Control LCD screen flash quickly. When it does this I can't turn on the A/C or the heater, etc. I have to then turn my car off and then back on and then it's fine. Any idea why it would flash, again only every once in a while, and then be fine once I restart the car?
Problem #3: I have noticed over the past few years a decrease in my fuel economy. I used to get about 300 miles per tank now I am at about 230-240 miles per tank. Car requires Premium Unleaded, I always used Costco, Shell, or sometimes Chevron. I replaced the EVAP purge regulator as I had read that some people noticed an improvement when changing it, but no change for me. It was a fairly cheap part from FCP Euro and a few minutes to install so I wasn't out much. Thoughts?
The car itself runs great, shifts smoothly, and for nearly 19 years old with 169K miles it's been a solid car. Any help from fellow owners here would be much appreciated and if you have gotten this far, I thank you for your time.
#3 · (Edited)
#1. Check your front wheel liners (if that's what you call them - the plastic in front of the wheel). Because you lost your skid plate, it likely means they aren't secure, and the headwind causes the plastic to be pushed into the tire. It wears a nice big U shaped hole in the liner, over time. Eventually you won't hear it because you've lost too much material.
#1. Check your front wheel liners (if that's what you call them - the plastic in front of the wheel). Because you lost your skid plate, it likely means they aren't secure, and the headwind causes the plastic to be pushed into the tire. It wears a nice big U sized hole in the liner, over time. Eventually you won't hear it because you've lost too much material.
Thanks I will take a look. Is this something I should be able to see from looking into the wheel well in front of the tire or should I look from underneath that area? Yesterday when I had my oil change the tech said there were some prongs that had to do with the skid plate and he could use tie downs and secure them for me. He went ahead and did it but last night I heard the sound again. The skid plate hasn't been on the car in several years but the sound is only something I have heard over the past few months so I kind of ruled the lack of skid plate out as the issue but I will certainly check what you had mentioned. Thank you.
#11 ·
#1, check your front driveshafts for play. Jack the car up (on stands) and push/pull the axle just past the inner CV boot. If there is play, it usually shows up under throttle as a vibration, but it can also make noise. I do expect it to be related to the plastic liners or the metal belly pan support.
#2, there is a procedure for pulling codes from the Climatronic. I am not familiar with it, but it should help you out.
#3, 230-240 for local commuting is normal, 300-340 for highway only driving. Is the CEL on? Has the car been scanned for codes? The V6 will run fine on regular gas until temps are 95 or above and then there will be slightly less throttle response.
#14 ·
Kinsella5 and I have been PMing about his #1 issue (the noise), and I wanted to post the same link I sent to him in case anyone is seeing this thread in the future. He said he noticed some material loss in the liner, and that is the telltale sign. The link below is a more extreme example, and more interior to where my hole developed (directly in front of the tires). It all depends on where the liner is not properly secured:
https://www.passatworld.com/forums/.../forums/volkswagen-passat-b5-discussion/357390-holes-cut-front-wheel-wells.html
As I mentioned, many of us had this problem (look at some of the comments). Lose skid plate (aka splash guard, belly pan) and/or someone doesn't install wheel liner retainers properly, and then you're stuck with an ever-widening hole (there's an example pic in that thread, that's also why I posted). It may just be this a different, #4 problem, and not the source of the noise, but if abnormal wear/shredding is starting to show, it's hitting the tire at least once in a while.
#17 ·
Just a quick posting to thank everyone who has chimed in here and my apologies for me being silent the last few days, just swamped with work. I will update later today with the latest for those who are curious as well.
A big thank you again to those who took the time to post a response and contact me directly. Here is the latest....
One thing I failed to mention in my original posting is that I have not had any type of "Check Engine" light come on, nor has one come on at all. The first thing I did was address the wheel well lining on my car. I don't have a skid plate/splash shield, and took a look at the fronts of the lining and did see holes. My friend owns a body shop so he put the car on one of the lift's and did see that there was a lot of play in the wheel well lining on the inside along with what appeared to be some rubbing. He thought that perhaps road wind was catching on it and causing it to rub thus causing that warping/cards-in-bicycle-spoke sound. He cut some bottom pieces from it and then zip-tied it down making it more secure. For the rest of that day, no sound but the next day the sound returned, so this didn't fix the problem. I did stop back in and he ran a complete diagnostics on the car. Here is what the results were:
For Engine Electronics there were three fault codes:
P1423 Bank 1, Secondary Air System: Flow too Low
P1113 Bank 1, Sensor 1: Internal resistance too high
P1131 Bank 2, sensor 1: Internal resistance too high
I did some poking around on YouTube and the internet and found that the P1113/P1131 codes are related to my O2 sensors. The P1423 could be related to the air pump and from what I read could be relay acting up.
There was another error code under AC/Heating/Electronics that came in as 00792 A/C Pressure Switch. What I have been noticing is my A/C does blow very cold but it does take some time to get to that point, however when I am idling either at a traffic light or sitting in the car for any reason, it doesn't stay cold until I start driving again. So my guess is this Pressure Switch is bad or on it's way out.
I do know a guy who used to work for Audi and VW as a master mechanic and has his own business repairing cars, but has been hard to reach because he has been swamped. He did call me this afternoon and I told him the codes. He said for sure the O2 sensors are bad, I believe I read that those should be replaced every 100K miles, I don't recall them being replaced on my car and I am at 170K. I am meeting with him in the middle as he wants to do a pressure check of the system as that warping sound could be some sort of leak as others here have pointed out. I should hopefully know more soon.
#19 · (Edited)
As far as the front inner fender / wheel well liners are concerned, not having a belly pan usually results in the fender liners getting a large hole burned through them by rubbing on the tire. Thefront lower edge of the fender liner has (2) attachment points that secure itto the belly pan.
Without those plastic anchor pins installed the front of the fender liner gets pushed up against the tire as you drive. The faster you go, the more it rubs.
Yes, these codes are related to your 02 sensors.
This code is related to the SAIP. (Secondary Air Injection Pump) It only runs when the car is first started (at least that is what it's supposed to do) for approximately (2) minutes.
Causes for the error code are usually associated to a leak somewhere in that circuit. Check the stainless steel tube the runs from the front of the engine, (there is a plastic hoses that connects to that stainless tube right next to and inside bank #1 cylinder head, that tube goes at a slight angle down to the lower right front of the engine compartment and is hooked up to the SAIP which is right next the alternator) follow that stainless tube to back of the motor (hard to see it's under the intake manifold) and it branches out into two pipes going to the back side of the cylinder heads and connected to the Kombi Valves. Many times there is a leak somewhere in this portion of the circuit.
Also check the function of the Kombi Valves with vacuum to make sure they are functioning. While checking with a vacuum source, the vacuum should hold, if it doesn't, the Kombi Valve diaphragm is bad and the valve will need to be replaced. Carbon build from the engine forms on the inside of the Kombi Valve. Engines with high mileage might have excessive build up and prevent the Kombi Valve(s) from functioning properly.
FYI, working on the Kombi Valves is a royal pain in the arse on the V6. Removing the complete air intake system including the manifold will gain you in-valuable space to work and function in.
Please acknowledge the other suggestions made here also. They arevalid points to check. Your explanation is good, but remember we are all pokingat something that we can’t see or hear.
#20 ·
Just a quick final update. Yes the upstream O2 sensors were verified to be bad. The Secondary Air Injection Pump (hopefully I termed that correctly) is also shot. I have a local mechanic who used to work for VW that I was able to connect with. He gave me a rather affordable price to replace that air injection pump and four O2 sensors. The random sound I hear every so often remains a mystery but my mechanic wants to spend some time with it. I actually sold the car today, buyer was informed of the issues at hand in detail, but was amazed at how the car looked and drove. I had a number of inquiries from people and the first person who came out bought it. I was pleased with the price, which included the repairs. I just felt after nearly 19 years of ownership it was time to get something new. I just want to thank everyone who took the time to assist me with researching these issues.
