EXPIRED: IMP Concepts - Cluster Integrated LED Boost Gauge
9.4K views 58 replies 23 participants last post by  ShokWaveRider
Okay, this Group Buy is now active and you can start placing your orders!
Please see below for ordering instructions. Due to the complexities of this modification, this Group Buy has recieved special permission from the top to be extended another month and will now run until May 30, 2003.
Please see these past threads for more information:
Integrated Boost Gauge Installed... +10 on the cool factor!
Integrated In-Dash Boost Gauge For The Passat Turbo, Perhaps
THE ELECTRONICS - for the DIY'er
The Control Unit with integrated night-use dimmer is $160 ($35 off the regular price) and comes with the customers' choice of any combination of green, yellow and/or red LEDs. This includes shipping, 4 scale drilling templates and complete instructions for the DIY install.
THE OPTIONS - at additional cost
1. Blue LEDs: $4.00 per LED (at cost) these are very expensive LEDs.
2. Installation of LEDs on tach dial: $140 ($64 off the regular price) and includes return shipping (to Canada is extra) of completed dial, control unit and instructions to reinstall the dial and hook up the four required wires. This service is on a "first come ? first served" basis and must be confirmed with Ian prior to shipping out your dial/cluster. NOTE: Complete clusters can be sent in but will incur additional return shipping costs.
3. External Boost Sensor: $20 (at cost) which is required for the non-Drive-By-Wire models and also includes instructions for installation.
ORDERING INFORMATION
Please email the following information to ianf-s@cox.net:
ClubB5 Member Name:
Email Address:
Real Name:
Address:
Model Year:
LED Configuration:
Installed: Yes/No
External Sensor: Yes/No & 20psi/30psi
Due to the custom nature of the control units that Ian supplies, the degree of precision he uses when doing full installs and the level of support he provides with all options, it is necessary that you communicate with him directly to arrange for your custom unit. He will then follow up with you providing final cost, payment options, estimated ship times and any other questions he may have about your particular installation.
You are no longer required to add your name or info to this thread to place an order since the 10 member minimum has been reached and ordering is directly through the supplier.
NOTE: The remaining information in this specific post is left for reference purposes only.
Please reply to this topic with your requested options and configurations required and I will track the list in this first message.
Please reply using the following conventions:
Bonthron (ClubB5 Member ID)
Yes or Tentative (level of commitment to this GB)
Chris Bonthron (Full name)
bonthron@mac.com (email address)
Canada (Country for calculating shipping)
M6J 3T1 (Postal Code/Zip Code for calculating shipping)
BBBBBBBBBBBBBBBRRRRR (LED configuration)(this shows 15 blues followed by 5 reds)
Installed: Yes or No
Ext. Sensor: Yes or No
THE LIST
Committed
#1 - Spanky McGee / Installed / 15B-5R
#2 - Silberne Bullet / Installed / 15Y-5R
#3 - Eurojet / DIY / 10G-5Y-5R
#4 - Ricardo / Installed / 4B-16R
#5 - jmurez / DIY / 16B-4R
#6 - ferndog32 / DIY / 4b-13R-3Y
#7 - Kosmas / DIY / Sensor / 3B-4Y-13R
Tentative
#1 - bfalchuk / Installed / 4B-16R
#2 - Todd / Installed / 16B-4R
#3 - shummer / DIY / 10G-5Y-5R
#4 - mrkazoo / DIY / 10G-5Y-5R
#5 - Hizay / DIY / 4Y-12R-4B
#6 - M Diddy / Installed / 4B-16R
__________
#2 ·
Re: FEELER: IMP Concepts – Cluster Integrated LED Boost Gauge (Bonthron)
Spanky McGee
Not Yes but Hell Yes.
Steven Conrad
Massivewow@yahoo.com
TEXAS, USA
78235
Installed: Yes, I'm an idiot
Ext. Sensor: No, Don't need it<p>So... thats 160 for materials, 140 for labor and 60 extra bucks for blue LEDs.
for $360 I'm in.
Re: FEELER: IMP Concepts ? Cluster Integrated LED Boost Gauge (Spanky McGee)
I'm tentative...and thinking of letting ShokWaveRadio install it. I'm planning on red LEDs with a Blue ones to mark the 5s<p>So, 300 plus 4x$4 for blues = 316
bfalchuk (ClubB5 Member ID)
Bryan Falchuk (Full name)
bfalchuk at mac.com (email address)
USA (Country for calculating shipping)
02116 (Postal Code/Zip Code for calculating shipping)
RRRRBRRRRBRRRRBRRRRR (LED configuration)
Installed: Maybe
Ext. Sensor: No
Todd (ClubB5 Member ID)
Todd Gilbert (Full name)
todd2gilbert@yahoo.com (email address)
32225 (Postal Code/Zip Code for calculating shipping)
BBBBRBBBBRBBBBRBBBBR (LED configuration)
Installed: Yes
Ext. Sensor: Yes or No ????
I am not sure if I want to run an external sensor. I have a 2001.5 so I know I have the sensor built in. But does someone know how accurate it is??? Would it be better to spend the $20 and get the sensor or does it matter?
Please email or IOM a response. Thank you.
Eurojet(ClubB5 Member ID)
Yes (level of commitment to this GB)
Shawn Maislin(Full name)
eurojet@rogers.com (email address)
L3X 2R3(Postal Code/Zip Code for calculating shipping)
GGGGGGGGGGYYYYYRRRRR (LED configuration)(this shows 15 blues followed by 5 reds)
NO Installed: Yes or No
NO Ext. Sensor: Yes or No
Ricardo(ClubB5 Member ID)
Yes(level of commitment to this GB)
Ricardo Santiago(Full name)
nucmed@caribe.net (email address)
Puerto Rico(Country for calculating shipping)
00681(Postal Code/Zip Code for calculating shipping)
RRRRBRRRRBRRRRBRRRRB(LED configuration)
Installed: Yes
Ext. Sensor: No
#10 ·
bfalchuk
Last light should be B and not R, otherwise you will get 3 Blue lights.
Correct the post & looks will get the same pattern.
#11 ·
Good point, Ricardo, thanks. I was thinking that they should all be red there because it's over the boost you should be getting with the stock K03/K04 Hybrid. It shouldn't get light up, so it's a way to save cash
#16 ·
JatTheWood said:
So this replaces the Tach??
No this will not replace the tach. It's a boost gauge.
#20 ·
What is peak boost? Im thinking of putting in a color at peak as an indicator. Is there a way to figure this out? or is it different with each chip?
Im just figuring out what to order, than I should be placing my order.
#21 ·
It's different with every chip. My UPsolute chip is supposed to have a peak boost around 14psi but I've also heard 15-16psi with this software, which is also where GIAC and APR are supposed to be. It will most likely also vary with any intake or exhaust modifications.
#25 ·
As for the DIY'er what exactly would have to be done? Is it as easy as plug and play or is there sodering the LEDS & stuff like that?
I would like to partipate in this Gb but it can get expensive with all the options, not saying it is not worth just a little out of my mod budget. :(
#26 ·
I'm working on a write-up on the whole procedure but my daily life is slowing me down a bit. :wink:
The Condensed Version:
1. Remove instrument cluster
2. Remove tach dial from instrument cluster
3. Make aluminum template for drilling LED holes in tach dial
4. Drill tach dial
5. Insert LEDs and glue in
6. Paint over LEDs to make opaque
7. Bend over anodes and solder together
8. Bend over cathodes and solder on wires
9. Tie up wires and paint assembly again
10. Solder separate LED wires to control board (this step may not be necessary)
11. Install completed tach dial back into instrument cluster
12. Splice 3 wires (+12v, ground and boost signal) into harness at the ECU connectors
13. Connect control unit to car and adjust
14. Install completed cluster back into dash
15. Go for a drive to marvel your handy work.
In hindsight I can honestly say that none of the steps are really that hard, it's just small detailed work that you have to be careful with. I'm sure you've seen my post with the pictures of some of the steps:
http://www.clubb5.com/forums/viewtopic.php?t=41630[/list]
