When I switch off the ignition, sometimes it goes off and sometimes it doesn't. When I step on the brakes a couple of times it goes off. Is there anyone that can help me out with this problem. 2000 Passat 1.8T a/t
Interesting idea passatboy. I think what your getting at is more of an uncontrolled ignition (also known as pre-ignition) due to hot carbon deposits on the piston heads. If there are carbon deposits, I don't know how they'd get there. Perhaps the computer is running the engine so lean that carbon is building up.I believe this is called dieseling. (don't quote me on it ) Might wanna search that.
My guess it's the brake light switch but could be wiring. To check the brake light switch, take the lower dash panel off under the driver's side and disconnect the electrical connector on the brake light switch which is mounted on the pedal cluster. If the problem goes away, it's probably the brake light switch.I pulled out fuse 13 and true enough, the engine stops. I put back the fuse and the dash lights were as if the ignition was on switched position till I stepped on the brake again. It's definitely got something to do with the fuse 13. What should I do next?
