About 2k miles ago, had my INDY install PBR Deluxe pads and ATE rotors on the rear of our 2001 1.8T. Everything was superb initially. A few days ago, noticed the proverbial rattle, clunk, metallic sound coming from the right rear when driving on a bumpy road, going over speed bumps, etc. If you apply the brake, the noise disappears. Just recently started driving around with the windows down, so don't really know how long the rattle has been occuring (you don't hear it with the windows up, stereo going, etc.).
I have spent the last couple of hours searching this forum, and have found this is a common problem with our cars. Some of the more common causes mentioned:
1) Missing or improperly installed tensioner spring (aka anti-rattle spring).
2) Not enough grease/brake quiet on the pad backing (it looks pretty tacky and like it was generously applied).
3) Bad rubber bushings (not real sure what or where they are).
4) Bad caliper sliders, or not greased enough (don't think this is it cause I really impressed on the INDY the need to grease those babies).
5) Could need brake shims (not sure if OEM pads had shims or not).
My question to the board:
With my particular setup (PBR Deluxe pads and ATE plain faced rotors), which is also very popular with many of you, any of the above five possibilities appear to be more likely? In particular, has anyone had to use shims with PBR Deluxe/ATE to solve this problem?
I will likely take the car back to the Indy, but just want as much info and education as possible before doing so. I feel confident the Indy will warrant his labor, but of course not the aftermarket parts (if they require shims for example).
All replies and advice appreciated, and thanks in advance.
