brake light changing for 2001 Passat?
1 reading
1.1K views 2 replies 3 participants last post by  swcrow17
I've seen posts for how to change 2001.5 and later model brake light bulbs, but I couldn't find any for earlier models. It doesn't seem I can pull back the fabric in the trunk to get at the bulb. Questions:
(1) How do I get at the bulb?
(2) Is there a certain bulb model number / type I should look for?
(3) Are such bulbs available at places like Wal-Mart?
#2 ·
crap....sorry i thought you were looking for 2001.5 reading > me
As for the carpeting though, I dont know if its the same but there are several torx screws at the top edge of the carpeting, and I believe you have to pull it out from behind some plastic trim. The carpet is "molded" and fairly stiff so it's a bit dificult to get out, but it will. I also removed the metal cargo ties points, but I dont know if that's necessary or not. The bulb should have the type/specs printed on it. Im sure any auto parts store would have it.
Hmmmm shouldn't be any different. That carpet is hard to get past at first. Your local auto parts store will have a book to look up the bulb number, but if memory serves me right, it's #7025 or #7225....something like that.
Walmart *might* have it, you just need to reference the book that they should display in that isle to make sure.
