I had side driver airbag blow off. instead of replacing the airbag I decided to follow Rustys instructions:
"Airbag resistor: 4.7 Ohm (not KOhm), 1/2 watt, 5%.
Sample part number: Fry's Electronics HWD47 - this is from Vortex, I can't verify it.
The airbag connector is the small one. On my '98 it is yellow and purple, with three wires: brown, yellow/green, and yellow/blue. The y/g and y/b are adjacent. These are the connections you want to bridge with the resistor. Secure with electrical tape (or equivalent) to insure that vibration doesn't cause intermittent faults."
I connected VAG-COM and tried to clear all the fault codes after I installed the resistor. Every intermittent codes cleared.
The only fault code that doesn't go away is:
01226 CRASH DATA STORED FOR SIDE AIRBAG DRIVER SIDE
35-00 - -
I heared that you need to do an extra step to reset the crash data. Some reset button under the hood...
Anybody has any information on this?
Please help
Serge
35-00 - -
Please help
Serge
