I don't use the AC too much but now i do i realise that it's not very cold (30 Deg C measured at vent when set to Lo).
The compressor switches on with an associated change in pressures. My Son is an avid HVAC guy and he hooked up his gauges to the service ports.
Pressures seemed ok, but on the pipes near the firewall the temperatures were the opposite of what we expected! The high side was very cold and the low side was just above ambient (in a hot garage/engine compartment!).
Son reckons its the Expansion Valve and i've seen the odd reference to it. Thing is, i've seen no diagrams of how to replace it or even a part number on ECS/Blauparts/Google, so i'm stuck-does the B5.5 even have one? (i'm guessing it must have).
Maybe the expansion valve is part of P/N 8D1-820-103-D Evaporator core?
Is it a dashboard remove?
OR, is it the small plastic assembly which installs into the tubing?
Item 6A (see attached) VW P/N 4B0820177 ; 8A0820177AA; 8D1260709A; 8A0-820-177-AA all shown as 'Expansion Valves'
70625[IMG]
Thanks in advance.
70625[IMG]
Thanks in advance.
