2005 Wagon Wing???
Tags
2005 wagon wing
1.6K views 13 replies 8 participants last post by  l5gcw0b
Anyone know where I can get a wing that mounts just above the rear window to keep dirt off of my window. I drive 12 miles of gravel roads and it's dusty daily.
#2 ·
actually, the wing will only make the dust worse. due to air's circulative properties, it tends to form a bubble behind closed areas or really anything in the trailing end of the object. the wing closes off a space which will then gather a lower pressure and circulate more air just simply due to vehicle speed and air pressure differentiation.
if you want to blame something for all the dust, blame the wagon :p
it's large & broad rear end acts as a giant aerodynamic drag bubble, hence which is why the wagon gets slightly worse mpg than the sedan, despite weight (although that does make a minor diff.).
hmm. that actually could do quite the trick to reduce the drag bubble, slightly increase the mpg possibly, as well as divert the air coming at the car downward.
worth a try. sure beats doing nothing at all!
i want to see results from that!
#12 ·
I have a Zender lip on the top of my wagon hatch and agree it helps trap even more dirt than before (which was a lot even then).
But I did see a wing, of sorts, posted on someone's wagon here, that attached at the outer edges of the hatch and held a wing rearward, leaving about 1-2cm gap between the trailing edge of the hatch and the leading edge of the wing.
I'm no aerodynamicist, but that seems to be the best way to burst the bubble behind the car while having minimal impact on fuel economy cuz it's not catching air, just splitting the air rushing over the roof, which would break the aero bubble created by the wagon shape.
