Can a car catch on fire after being cold for at least 4-5 hours? Well police and firefighters not sure what caused the fire. Firemarshall will be here in the morning. Will post pics then. A poor brand new 2003 passat just bit the dust.
Sucks to hear that dude...LaZy4zNbOi said:Can a car catch on fire after being cold for at least 4-5 hours? Well police and firefighters not sure what caused the fire. Firemarshall will be here in the morning. Will post pics then. A poor brand new 2003 passat just bit the dust.
Yes, check the other threads above. Had the car been driven in the 4-5 hours prior to the fire? If so, it might've been caused by something touching the turbine housing. Had you or anyone else been under the hood in the past couple of days? :nervous:Can a car catch on fire after being cold for at least 4-5 hours?
Sucks...that fluid leak seems like a likely culprit. The turbo stays hot for a long time if the hoods closed.jwilker said:bummer man. That really sucks. Let us know what they find out as the cause.
J
sounds like a design flaw, to me. almost like there should be a cool-down fan that runs for a while after the car is turned off.not_too_shabby said:Sucks...that fluid leak seems like a likely culprit. The turbo stays hot for a long time if the hoods closed.jwilker said:bummer man. That really sucks. Let us know what they find out as the cause.
J
Already been done. They are called TurboTimers. They tap into the ignition, and other connections to enable the car to stay on for a certain amount of time, and then turn off. Probably a good $100 investment.BenjiBoy650 said:Anyone tried that or think it might help?
What he said.Talon Load said:Let me be the first to say THAT SUCKS. I hope everything comes out o.k.
