2002 Passat high beams not working.
155 views 1 reply 2 participants last post by  DearSir
Another issue in a short(?) list of things to fix, as I resurrect a 2002 Passat 2.8 GLX AWD that's been sitting for 8 years. I can't get the high beams to work. I've checked/changed the bulbs and fuses. I've swapped out the headlight switch. I've even plugged in a spare set of new headlights. All of the other lights work, even the "city" lights in the high beam reflector - but no high beams. I also get no blue indicator light on the dash for the high beams. Next I'm going to check the actual high beam switch on the turn signal stem. Is there possibly a relay that controls these lights? Thanks!
