2000 Passat 1.8l
Desperate - Need help please.... tired of driving my daughter to work...
Trouble began with a no starter crank problem, fuel door, trunk, key remote, interior lights not working
Checked all fuses with ohmeter and found no blown fuses at side panel box, engine computer box, and several others I found drivers side far under the dash.
With Key On, Found no power at Fuse #28 (fuel door) #3 interior lights, #4 Lights (Bs-x-32 ?) # 32 (Engine) and 1.7v at #34 (engine)
Tested Starter motor by jumping power to solenoid at starter, cranked normally. Found no power coming into starter solenoid when key turned to start position.
Tested Starter Interlock (Relay #185) power out at position 30 with key in start position and verified power. Tested starter by jumping power from position 30 to 87 - engine starts and runs normally.
Checked for power at relay power circuit pos 85 and 86 connectors... NO POWER.
I have been searching the forums and finding many similar issues that indicate it could be the comfort control module? I checked the condition of the ground at the CCM and visually inspected with nothing unusally...
I beleive my only option is to take it to someone who can connect a tester to the car? Anyone have recomendations.
