Hey Everyone,
First time poster here, sorry if this isn't the right spot. I have searched the forums and haven't found anything that combines all three problems. To start things off, I have an 03' 1.8T Passat with 135k miles on it. A few weeks ago my engine started to run a little rough so I had the car looked at at the local VW specialist and a place that I have taken my car to before. They diagnosed that the engine breather PCV is defective, but were charging too much for my current budget, so I was thinking about tackling the project myself. I haven't done a project like this before, but I feel like I can do it.
Here is snag #2, this past Monday I was driving the car and it barely had any power. When I got to work (5 mins after I lost power) the engine was smoking so I popped the hood and noticed that the catalytic converter was red hot. So I thought I just had another issue. After talking to a few guys at work we decided to take a look at it and we pulled the coils out and lo and behold two of the coils packs were covered in oil. After doing some research it sounds like my gasket valve cover may be forcing oil into the spark plugs and coils because of the PCV breather, but now I wanted to know if the catalytic converter issue could be stemming from the PCV issue or if that is just another issue in itself.
I have no issue going out and replacing the spark plugs and coils, but I don't want to do that if oil is getting forced in there. So basically I need some expert advice here, does it sound like if I replace the PCV breather and coils and spark plugs, then maybe the issues will all be solved? Or is the catalytic converter now and issue unrelated?
Thanks in advance, once again sorry if this is a repeated topic or in the wrong place.
