So story is next ...
So gar the car has still been maintained at stealership at vw..
3 days ago i decided to wash the damn thing ....so i started her up, drove it next to the house and turned her off everything was working fine ....
After washing and vaccuuming i wanted to re park the car and it would crank but wont start!!!!
Found out that pump ia not engaging, so i hotwired the relay and with the relay hotwired the car starts up from half the turn from key... Soo i suspected the relay was bad so i went ahead and ordered new one and replaced that ...nothing!
Crank and camshaft sensors are good i checked , speed sensor aswell , as i crank the engine the odo.m. shows roughly 200rpm consistent....fuses are good so im lost...
If i hold down the FP relay manually then the car starts right up , if i lwt go it dies....
Ecu box is nice and dry , no warning lights or stored codes , coil packs and spark plugs are good and recemtly switched , before that tje car didnt have any idle nor operating problems prior to that...
Maybe the ecu relay? But which one is it ....or is there any wireing under driver /passenger seat that i could od nicked during vaccuum?
(Sorry if the english ia bad , im from estonia)-thanks in advance.
