Hello all, great forum. I have searched this issue and it seems most have had mechanical timing issues.
I am getting p0340 repeatedly. After clearing it. It shows back up as pending within 45 seconds or so. I have pulled the valve cover and verified the correct belt and chain timing. I have also swapped the cam position sensor with another used one from a parts car that didn’t run. Same thing, but since I couldn’t verify it was good, I have a new one coming.
I purchased this thing three years ago not running. The CCT had broken shoes and it had jumped time and bent the intake valves. I pulled the head and had the intake valves replaced, installed new belt, tensioner, idler, and water pump as well as a new cam chain tensioner. I have put about 20,000 miles on the car since then and it has been a decent little grocery getter.
The car still runs, but maybe a little rough. It also runs the same with the cam pos sensor unplugged but does have an extended crank time that way.
Has anyone seen issues where possibly my CCT is not changing the cam timing as the ecm is commanding, and causing the cam position code? I don’t remember where I got the CCT but it is had to get good parts these days unless you go OEM and it was definitely not OEM. I don’t have any oil pressure alarms and have been keeping the oil changed, but this was a rough ole car when I got it so I assume it has had a hard life. Possible weak oil pressure keeping the CCT from functioning correctly?
