We have a 99 passat and there is a bad problem with water coming into the cab - front driver side.
I cleaned the drains under the battery and by the master cylinder and made sure the plugs beside were sealed properly...
We still have water coming into the cab and it seems to trickle down (pretty quick) behind the plastic foot brace to the left of where the clutch pedal would be if it had one. I took the plastic foot brace and trim off so I can clean the water out every time it rains.
Where should I look to hopefully solve this problem?
Am I missing a drain or something?
Thanks for the help
Thanks for the help
