| Register | Blogs | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Club B5 Discussion area for the B5 Passat, production years 1997-2005. |
Thread Tools | Search this Thread |
#1
After deciding to buy a trailer for my Variant, I went into research mode to determine how to wire up the lighting for the trailer I plan on buying in the next couple of weeks. 'pass-variant's no-splice method inspired me to figure out how to do this properly. As the rear of the taillight on his 2001 is quite different from the 2002 that I have, I had to get a bit more creative. One main difference is the additional takeoff for the side marker lights that are not on a 2001.
The hardest part was determining the German shortforms printed on the bulbholder which I have summarized on the wiring diagram. I was able to build my own harness, make it easily removable and did not have to cut or tap into any existing wiring! I am not an expert in wiring but it really wasn't that difficult once I had the parts. I had confidence it would work and tested all circuits, reviewed Bentley wiring diagrams and created a wiring diagram that I can now share with my fellow B5ers. This wiring took me under 2 hours and estimated costs (in Canadian dollars) are as follows: Converter - $30 16ga wire - $5 Male (4 pack)/Female (4 pack) Insulated Disconnects - $5 Heat Shrink Butt Connector (4/pack) - $5 VW wire (2) - $11 VW connecter plug - $1 Crimp tool - had it Wire Strippers - had it Solder and Gun - had it (from rear fog mod!) ![]() Download wiring PDF of above here ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now I am just waiting for the hitch to arrive any day now .... Last edited by leadfoot; 02-26-2007 at 05:08 PM. |
#2
![]() hahah just thought i would show you this
#3
Quote:
#4
Where did you find your HH electrical converter for that price? Did you get it in Canada, if so, what store.
thx |
#5
Quote:
http://www.rackattack.biz/ Rack Attack Toronto 127 Laird Drive Toronto, ON, M4G 3V4 Canada tel : 416.424.1201 Since you're in Vancouver: Rack Attack Coquitlam Unit #5 1300 Woolridge Avenue Coquitlam, BC, V3K 6Y6 Canada tel : 604.526.7225 Rack Attack Vancouver 98 West 3rd Avenue Vancouver, BC, V5Y 1E4 Canada tel : 604.872.7225 |
#6
#7
not sure i'll ever be hitching to the passat, but your drawing is definitely needed in the info forum.
*Paging Rusty* |
#8
How long have you had this installed?
Only reservation I'd have about the schematic is the trailer running lights. The schematic has them in parallel with the rear running lights which should still be the standard 21 watts. If you end up blowing any fuses due to current draw issues, you could always install a larger fuse and check how hot the wiring gets after ~30 min. :Yikes: |
#9
Quote:
#10
Just installed it myself today. Thanks for all your help bro, it looks nice and clean no spliced wires!!!
I will see it in action this Saturday, I will be pulling a 4X8 trailer full of my new kitchen cabinets. |
#11
Quote:
....glad my post helped out.
#12
Thanks to leadfoot.
I completeding my trailer wiring install today. I purchased a Reese Tow power trailer light converter from Canadian tire, on sale for $55. Model 74107C which is basically a rebranded Modulite controller with Circuit protection and it is powered. I fished the + and - power lines to the passengar side and crimped them to a cigarette plug adapter. When I tow I simply plug this in to one of the two power jacks in the hatch area. When not in use I stuff it in the cubby. Using leadfoots no splice method I connected all the taps, but, instead of soldering on a connection for the running lights I just used a quick-tap-lock thing. When towing I just plan to close the hatch on the cord and dangle it out the hatch. When not in use I'll roll it up in the cubby. Tested her out and voila! perfect. Thanks for the beautiful instructions. cheers! |
#13
Thanks Leadfoot.
A few quick question: - Should I expect to be able to get the VW specific parts (i.e., the wire and connector plug) from my local dealer, or will I need to order them? - From the diagram, it looks like there are 3 of the VW wires used, but you only list two - In the following photo, is the solder from you or was there already some there? ![]() and finally: - The diagram lists three of the connections as "optional". Can you explain what will not function if they are omitted? Thanks again for the help! |
#14
Quote:
1) Wire and plugs available from your VW dealer. The VW wires should be in stock. The small plastic plug took a day to order in. 2) The wires come with two ends and you cut them in half, therefore you actually end up with 4 connectors - you'll have one left over. 3) I soldered the wire to ensure a permanent connection (can always be heated up and removed if required). It is very easy to do. If you can't solder you could wrap the wire on the metal or 'tap' into the SL line. Just buy a solder gun, read up online about soldering and try it out. What's the worst that can happen? I haven't done much soldering in my life but it isn't rocket science. 4) The 'optional' connectors only serve the purpose of if in the future I want to sell the car and remove the wiring harness without anyone knowing it was installed I can disconnect it. Or if under the chance the convertor needs replacing, it'll be an easy disconnect. In reality, I'll probably never need them but thought it gives me flexibilty in the future. Hope that helps you out. |
#15
Great! Thanks for the response. One more quick question:
How do you get the green wire from the converter all the way over to the right bulb holder? |
#16
I tucked it under the chromed/stainless steel trim piece that goes from side to side at the sill (around the latch). I used a bit of electrical tape to ensure it stays there...you could also use some silicone or caulking if you have it lying around.
#17
Cool. Thanks again for the help. I'll be trying this in the next few days (once my parts arrive) and will let you know how it works.
#18
Why did you need the extra 16ga wire for $5?
#19
Worked like a charm! Thanks!
#20
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
