I have a 2003 Passat Wagon AWM and when I turned it on today all the PRDN etc lit up on the dashboard. In other words it wasn't just P since it was in P. I was able to change gears (although there was lots of popping from/to reverse) and drive, and when I shut the car off and turned it back on everything was back to normal. I've read this is a common issue and like many others I received this code:
P0706: Transmission Range Sensor Circuit Range/Performance
I also received this fault code, listed as possibly pending or manufacturer specific:
C02C2: Unknown code - More information may be available on the web
I am using the Torque app with an ELM bluetooth OBD device to get the codes. I do not have VAGCOM. Google didn't give much on the code and this forum doesn't have anything on it. I found an audi site that has it listed and says it's a transmission related code but nothing else.
For now I've cleared the codes however does anyone know what it is, or have you seen it, or if you are a VW tech would you mind running the two codes together and post what comes back so I can get a better handle on fixing this. Thanks
SOLVED: Thanks to the forum members here. The culprit was both corroded wiring and a bad transmission range sensor (aka neutral safety switch, aka multifunction switch). If you don't want to read all the posts see post #17 for the solve. I never found out what the C02C2 code was.
Update March 2022: The replacement MFS failed after 7 years with code P0706 so I've replaced it again. I first tried a generic version which was defective, so I bought another Standard Motor NS-349. Also this time I put the car on jack stands and removed the driver's tire so I could work from the wheel well, which was a lot easier.
