1 - 13 of 13 Posts
Try rubbing brake fluid on the headlights, just be careful not to get any on the painted surfaces. I tried this and although you can still see some oxidation, the yellow color is completly gone. Not sure how long it will last until they turn yellow again, but $1.89 for a bottle of brake fluid, you can't beat this cheap DIY'er.
- chris
- chris
OK ... I'll bite .... how did you figure this one out ?
Anyone else give this a try ?
When I bought the car the headlights were yellow and oxidized. So I mentioned this to the dealer and he said " dont worry, when you pick up the car tomorrow I'll have them looking like new." Well, when I picked it up, they did look like new. However, a year later the yellow came back. So I went back to the dealer and asked what exactly he did, as I cannot afford new headlight just yet. He told me, just rub some brake fluid on them, so I did. Low and behold, they look pretty good once again. All the yellow is gone but there is still some slight haziness. Perhaps a follow up with some Meguires Plastix would finish the job, I just haven't gotten around to it yet..sorry for the slow reply.
Yoinks, brake fluid? Not the safest thing to be swishing around your car (or having in contact with your skin). A safer approach is wet sanding with 1000 and then 1500 grit sandpaper, followed by a final rub with the Meguiars plastiX stuff. There's a thread on VWVortex that has a full howto on doing this. Too lazy to look it up, but it's out there...
I did alot of research before I tried the brake fluid and saw all the posts about wetsanding and then using a rubbing compound.I also tried using just the Meguires Plastix, which didnt work for me, maybe you need to apply the Meguires with an electric buffer for better results. I also didnt want to spend the time/energy wet sanding and buffing crappy OEM headlights which I am going to replace anyway. I just wanted a cheap temporay fix so Im not driving around with nicotine stained lights. So heres what I did in detail: Got some gloves, taped off the painted surface around the headlight just to be safe. Then applied a small amount of brake fluuid to a 100% Terry cloth and applied in a circular motion like the Karate Kid. I did a little area at a time and it took me a whole 10mins to do both lights. Someone else has got to try it! I wouldn't post it on here if it didnt work, just dont get it on any painted surfaces.
Discussion Starter · #9 ·
Everyone is missing the point...this was only for the yellow...and was just meant to be a cheap/easy/quick/temporary fix if you didn't want to wet sand OEM headlights you will be replacing...and the plastx didnt work nearly as well!
Dont knock it till you try it : )
be advised, mag's plastX is NOT a cleaning solution.
from what i've read (of xyro's bottle of the goop) it's seems to be a touch up solution meant to repair the worn out and Oxy'd state of the plastic by basically applying a new coat of plastic.
the reason the brake fluid thing works like that is because it is able to get into all the nooks and micro-crannies of the texture of the lights.
i'd suggest the wet sanding....seriously...i tried the brake fluid and it turned my lights real foggy....the wet sanding is really not hard at all....look at the threads i have posted on cleaning the headlights and all the info is there...and i used meguiars plastic cleaner and polish....loved the outcome for UNDER 15! bucks....
1 - 13 of 13 Posts
