1 - 3 of 3 Posts
Super Moderator
Years and models can be different on how and if its possible. With the early B5s you had to add something like the Alien Remote Controller. Post you car info up too.
If this is a B5 or B5.5:
That one requires a (small) re-write of the CCM software - it's not a quick 'adaptation' setting.
Alientech controller; KVW100 programmer (which will permanently lock you out of any other code changes to the CCM, forever), or VDS-PRO (which requires a serial 409.1 KKL cable to connect to the CCM. Also, runs in DOS.)
I'm set up to do bench coding on B5.5 (1C0-) CCMs - you mail it to me, I tweak it, I mail it back. I'll eventually add B5 (1J0-) CCMs to the service (need to get plugs & a CCM to set that one up. Will do that later, depending on responses.)
Thread: http://www.passatworld.com/forums/v...657-ccm-software-coding-mail-me-your-ccm.html
B6 can be done in adaptations.
Definitely need vehicle info posted up.
1 - 3 of 3 Posts
