Status
Not open for further replies.
1 - 19 of 19 Posts
Like the title says:
Wife now has an '02 4Motion wagon, I would like to put kid seat anchors in it, so we can graduate the boy out of a harness seat.
Minimally, I need a right anchor (they're different, because 4Motion), will buy the set.
Model years 2000 thru 2002, all the same - MUST be 4Mo (FWD is different bits.)
EDIT: If I re-read the bulletin correctly, I think that MY'03-04 still used the bolt-in brackets (but, they were factory installed, instead of dealer accessory); MY'05 is welded. So, that should help my search....
Anyone have a set that they aren't using anymore, want to sell them?
*Update: I found actual part numbers, for those who have a Pile O' Stuff that they're sorting thru:
3B5813545A (left), 3B5813546A (right.) Should be stamped into the parts.
You mean the little hooks on the back of the folding seat? I thought they were the same, just a 10mm bolt holding them in place. I removed and shipped mine out years ago.
Negative - the base brackets (the ones that go below the base of the rear seat.)
Are bolted down, 'dealer accessory' thru MY'02.
If I read the bulletin correctly, MY'03 and '04 are still the bolt-on bracket (but were standard equipment); '05 is a welded component.
I'll check my car in a day or two to see if I have them. Can you send a pic of what they should look like?
I don't recall seeing that under the rear seat, but it's been 3 years since I had it up. I'll check and let you know.
I am unsure of the U.S. models, but I know in Europe B5.5s did not come with the brackets installed. I ordered the bracket and fasteners to mount the bracket myself in our August 2004 manufactured Passat. The mounting holes are present under the rear seat but are covered with a round piece of tape.
You might have luck searching eBay and salvage yards.
None on mine.
Discussion Starter #13
February bump.
Still looking for these. Tried ordering a right side bracket from VW; is "on backorder" now, doesn't look like it's available anymore.
Anyone? Bueller?
Discussion Starter #15
I don't know how much you're willing to pay, especially once the shipping is added.
ORIGINAL-RECHTS-8E0813546A
The item price is reasonable (~$90, off the top of my head.)
But, there's this little detail:
"Dieser Artikel wird nicht geliefert nach Vereinigte Staaten von Amerika" = "This item is not delivered to United States "
Thanks for trying, though. :)
"Where there is a will, there is a way..."
And if the item is shipped to a forum member in Europe first, then to the U.S.....:poke:
Original-Isofix
Discussion Starter #17
I was going to ask if you were willing to help a brother out.
Then, I poked at eBay again - this time with the Audi number. Found a set here in the States, for $100. Woot!!!! :barmy:
Discussion Starter #19
Indeed. They've been a challenge.
But, mission accomplished, it seems - should have them by next weekend. :)
1 - 19 of 19 Posts
Status
