1 - 9 of 9 Posts
I am prepared to replace my wiper blade inserts as per vuvision's great write up in the Information Forum. However, the write up starts with the B5.5 aero blade (the part that holds the actual insert) already detached from the wiper arm.
How do you remove the wiper blade from the wiper arm?
Thanks.
Sharky,
Thanks for the instructions. Do I understand correctly that I pull the blade striaight out away from the direction of the wind shield as opposed to sliding the blade off the arm towards one side or the other?
Also, to replace the arm, do I just snap it straight back in?
Again, thanks for your help.
Sullie,
Yes, I have seen vuvision's write up on the inserts. It is that very insert replacement that I as asking about.
Thanks for the tip on the gtg. I have been keeping an eye on the events forum but I must have missed it.
basically, do what sharky said
but there is no clip tp hold them on., just lift the arm up and start to move the wiper around if you dont understand sharkies explanation. after playin around w/ it, it should just fall off, they aren't attached very well
6th Grade
Slider said:
Sharky,
You're always so good at dishing out that tough love!
Cheers.
Yes I suppose I am, but you must trust in the Sharky and not make things harder than they are until things ACTUALLY get difficult.
1 - 9 of 9 Posts
