OK so randomnly my windshield wipers stopped working. If I manually move them up and then hit the switch they will go back down. They just won't go up. I'm guessing it's either a relay or a fuse. Any suggestions on this? I'm trying to find out exactly what fuse/relay I need to check for this. Supposed to rain for the next week starting tomorrow!
Turned out they were installed properly after the windshield was replaced. Easy fix thank goodness
that was a long time ago and doubt if they are even active, but you can check the relay, it is behind the accessory cubbie hole to the left of driver's knee, open ,bend "stop" tab to release door to gain access. Check the fuse, do not recall which one it is however ,there are three fuse panels ,one under hood and one at either end of the dash.
