1 - 9 of 9 Posts
my passenger side winshield sprayer stop working. anybody here had this problem and what did you guys do to fixed it. i've looked inside the sprayer housing were all of the hard plastic tubing is connected and i don't see anything wrong with it. all i know that it is not spraying the windshield fluid out.
I would swap the passenger side nozzle with the driver side nozzle to help isolate the problem. But, if the driver side work on the passenger side then replace the nozzle if not probably start looking at the hoses
A pin may be too thick - try a long strand of wire. The wire inside those twisty ties you get in retail packs or like you put on sandwich bags do the job.
If it still does not clear try blowing out the affected tubes with an air line at the garage.
1 - 9 of 9 Posts
