CCM is probably flooded or corroded wiring.
my thoughts about that are high too, but i went in there i have both power and ground to the regulator, and resistance from regulator to the window switch, and still nothing. im thinking the motor. but it could still be ccm because the dome lights dont work
My window switch isnt connected, but 3 of my windows just went down. the switch needs replacing anyways but can anyone tell me why this just happened?
It could also be defective wiring at the driver's door post area. Sometimes the wiring insulation breaks and wires touch each other acting like you have the key in the outer door handle unlock position. Did the doors unlock also?
