Does anyone know if the white gear that holds the wire rope is included in teh OEM regulator replacement? Mine got all chewed up because the wire fell off the grooves and began rubbing the gear raw
Super Moderator
Yes its on the new one, the only things you have to move from the old regulator to the new regulator is the electric lift motor, door latch assembly, and wiring holders.
If all you need is the gear let me know. I've got a brand new front left regulator minus the clips that I'd be willing to part with.
