1 - 12 of 12 Posts
Re: that link didnt work
guy022077 said:
DaddyMatt said:
I'm not sure if that one will fit, you might want to compare it to the 3362 tool referred to in the following valve procedure:
http://1.8t.org/~quattroman/Audi B5 97-2001/Engine Mechanical/1.8T 5V (AEB & ATW)/Engine/15-32 Valvetrain servicing.pdf
hey hey that link didnt work
Doh! It did work...looks like their server is down for a bit...maybe later. I saved the (823kb) PDF file; PM me if you want it and I'll e-mail it to you.
Discussion Starter #8
oh i got it i just kept deleting the path untill i got the parent diectory....i got the file but that tool does not look at all like the sears one...maybe i am just out of luck and ill go buy the 3362 tool. thanks though.
One advantage of the 3362 tool is that you can use it without removing the head (to hold the valve in place from underneath)...but as I recall, this is not an issue for you, since you had to pull the head to replace your valves anyway!
I just found out that Zelenda has the 3362 tool, but they want ~$150 for it! :shock: For 20 bucks, you might want to try the Sears tool first, or maybe even check E-bay for a used 3362??
Let me know if you want some help turning wrenches, etc. My time is tight between work and family, but I'll try and give you a hand if I can...we Club :b5: 'ers gotta stick together!
Discussion Starter #10
thanks
Let me know if you want some help turning wrenches, etc. My time is tight between work and family, but I'll try and give you a hand if I can...we Club:b5: 'ers gotta stick together!
thanks for the offer...but my time is the same way i never know when i can work on it but i will keep you in mind if i get a free minute thanks again.....we Club:b5: 'ers gotta stick together and i do have a vag if you ever need one.thanks again :lol:
Cool! I'm planning to get a VAG-COM (some day) soon, as I've just gotten the perfect laptop to run it on...I'll keep you in mind if I need to pull some codes. :thumbup:
BTW, have you seen that All-Pro has broken ground on their new store? (just west of Sam's Club) I'm guessing you're in the same boat as me warranty-wise (I'm about to hit 120,000) but it's good to know we'll soon have another option for parts aside from driving to G'ville or ordering on-line.
Discussion Starter #12
yes i did notice
i did just see it a few days ago and i am right at 110233 and no more trips to orlando for parts cant wait..
1 - 12 of 12 Posts
