Will crank but dies after a second or two.
1K views 2 replies 3 participants last post by  VAGguy
My friend has a 2006Passat and he recently put 4 quarts to many of oil and also cut his power wire with the switch on to add a amp wire. After all was fiixed like draining the oil and splicing the power wire back together the car will crank but dies immediately. Can someone give me some answers?
#2 ·
Do you mean, the engine will start, but stops within a few seconds ?
If that is so, you have an immobiliser problem.
2006 is not a B5 Passat. Moving to the correct forum. Please become acquainted with the site by reading through the new member forum. If you had, this would have been your third post.
