1 - 3 of 3 Posts
Does anyone know if 17" VW Sonoma wheels will fit on my 2007 Passat 2.0t FSI?
Buying used, but they look perfect. They, and my car, are 5 x 112, but is there an offset issue I need to consider?
Is $300.00 for the set a good price? One is missing VW center cap.
Also, How do I (and where from) get a correct center cap replacement? Do dealers gouge a guy on these kinds of parts?
Anything else I need to consider?
Thanks!
Turn them over the off set should be molded into the back of one of the spokes, eg et37(mm). Match that spec against your current wheels. There probably won't be much difference. Plus or minus 5mm(even 10mm) will work fine. The wheel just moves in or out under the fender without much consequence. If you like the wheels, pull the trigger. You can always resell. There not much risk involved either way.
1 - 3 of 3 Posts
