1 - 20 of 54 Posts
That is not as much of a problem as you might think it is. I can think of 2 different ways to make this work but both involve "losing" your valet key.
Pete
Let me know...
If it works I will gladly replace my remote start system with an integrated system/key. Right now I have 2 remotes (the flip key and the remote start) One with an integrated key would kick butt.
Discussion Starter · #6 ·
There is no question that this can operate with a remote start. I know that. I just have to set the trunk release as the remote start activation since the locks will open the trunk anyways. I just have to make sure that the key can be cut for a VW key.
As far as the people with immobilizers are concerned, just use a 555B to bypass the immobilizer system for remote start, problem solved!
How Will this Work With my 2003 Passat ????
I dont know a lot of electronics and live in the dominican republic where you order keys to germany with your car code.
Regards,
Rayo
Dominican Republic
How would you get around needing the trunk release on a Variant? The hatch doesn't unlock with the car on a Variant and if you disable the button on the remote you'll have to use the button in the car or the key in the hatch lid.
Paul :thumbup:
Discussion Starter · #16 ·
I would need to make some programable circuit to make a two button combo wouldn't I??? I don't think the alarm will pulse both lock and unlock at the same time if I hold them down. I'll have to check and see but that's a good idea. Maybe use two relays?
Relay 1
85 lock
86 12v
87 to unlock
87a empty
30 to 85 on relay 2
Relay 2
85 from 30 on relay 1
86 12v
87 ground
87a empty
30 to remote start negative activation wire
Sound right to you or do you think there is another way I could do this?
Sounds right to me. The pulse should be strong enough if you pull the negative lead from the battery and use the relay as a switch instead of pulling from the alarm brain. Does that make sense?
Paul :thumbup:
1 - 20 of 54 Posts
