Got an AWE Stage 2, 12 or 14# aluminum flywheel with a spoked clutch disc. Works well, it is a bit easier to dump, but only rarely. The clutch engagement isn't as grippy as I'd expect, but it does hold well for occasional launches and power shifts.
Why did you opt to use the OE flywheel if it's not a secret?Kenny Payne said:I've had the AWE/Southbend Stage 2 in for about a year. It's worked just fine. I decided to go with the OE flywheel.
Kenny
