1 - 20 of 187 Posts
ATW & AUG seem to be most reliable in terms of less crap going wrong. Of course, this is completely subjective based on reading thousands of posts.
To all you V6'ers. Up at 6000ft where I live, a stock 1.8t (AUG in my case, & a 5 speed) can easily run side by side w/ a modded MkIII VR6 Gti. Or atleast I can. So IMO if you live at any kind of altitude opt for a 1.8t. At sea level I'm sure the 6 screams, but here in CO they're all bark and no bite ;).
The VR6 and the 30v 2.8 are 2 different animals with hp difference of about 20 and tq of about 30. Make sure you're comparing the right powerplants first.
Theres just something wrong in my mind about powering a car as big as the Passat with a 4 banger. Call it personal preference. Moddability goes to the 1.8 no question.
One more time, and I'm outta here
In the past I would have aggreed however after getting a 1.8T and seeing it pull away from a V6, I know the pull is there. However with all the sludge problems, I would prefer a V6.
You are going to make me cry...........All the things I read about in this forum. The V6 is by far the least amt with problems here
Spend the exact amount of money on the two engines; 1.8t eats the v6 alive! V6 has better exhaust note, though. Personally, I'd take a twin turbo from a S4
I constantly run my v6 with man. up and down to Virginia City, which sits well over a mile high, and my car has no problems whatsoever. It all depends on the driver. Can't work a clutch and know when shift, up or down, of course you're gonna lose. :biglaugh:
AUG, no mechanical problems yet so I guess its ok.
No oil burning either. Cam seals replaced under warranty, no leaks for the last 50k.
1 - 20 of 187 Posts
