1 - 9 of 9 Posts
jwil's write-up here:
http://www.clubb5.com/forums/viewtopic.php?t=33915
He says,
"Using a 3M Scotchlock connector attach one wire to the WHITE/BLUE wire at pin 3 of the blue cam lock connector attached to the back of the instrument cluster. (see figure 11~13)
"**NOTE** This wire is for speed sense, without this, the navigation unit can not function. This MUST NOTbe connected if your radio is equipped with GALA speed sense. A short circuit could result and cause significant damage to your car! "
The speed sense wire should be the same whether it is GALA equipped or not and it is the blue/white wire to the cluster. larrs and I have GALA and we tapped into it with no problems.
1 - 9 of 9 Posts
