1 - 13 of 13 Posts
well when i get my car i want to put a cat delete and i need a 3'' downpipe unles, is there any way that i could put the 3'' cat delete at the end 2 5'' or put the 2 5'' downpipe biger so it could all match. well is there s no any way to do that so i would like to get a 3'' downpipe..
Consider a high-flow cat. If you remove the cat, in addition to polluting the air, you will fail your emissions inspection, meaning you can't drive your car.
SirWired
4th Gear (Wax on Wax off)
Unless your going 3" all the wa tthrough you wasting time and effort .. a pipe is only as big as its smallest orifice.
the deal finder!
i'd say a 3" dp with stock exhaust is good if you install a cut-out in the dp, for those who want a stock-like set-up most of the time.
Discussion Starter · #6 ·
so if i go 3'' cat delete and a 3'' custom pipe and at the end i put a muffler would that give me a really nice performance exhaust???
Most cat deletes are 3 inch an reduce slight in size, you can run them with stock down pipe, so I would find a 2.5 inch downpipe and exhaust and call it a day.
so thats how people in long island talk huh
i just got a 2.5" high flow connected to my gt28, it seems plenty big unless you're going HUGE TURBO, im talking 400+ hp
1 - 13 of 13 Posts
