1 - 13 of 13 Posts
i want wheel spacers but i am not sure what size to get . i have 18/8 wheels please help me out....the guy i talked to says 8mm on each side was as far as i ahould go. TIA
casady
yes it is lowered with H&R sport springs my tires are 225/40/18 not sure about the offset though
Salty Moderation Stylez
offset and suspension make a huge difference on what you may "need"
offset can be found on the wheel either with ET ___ or ___ mm
another note, when running anything wider than 5mm please use longer lugbolts
ya i know all about longer bolts i just wanted to know what sizes other people run. i cant check my offset because the wheels are in a garage about twenty minutes away.....i know that i can run 8mm i also wanted to know if anyone has run diff. offsets for the frunt and back.
see thats what i want i would like to do 20mm in the back but i am not sure about 20mm and 18/8 they are 35mm ......i just called me friend ,he has my wheels at his shop
Discussion Starter #9
shmove so you think i can get away with 8mm in the frunt and 15mm in the back?
8mm in the front might be a bit much.
maybe try 5mm up front and the 15mm in the back?
i know there's a couple guys in here who are running that set up with pics. maybe they'll pop in here and show you what it looks like.
Discussion Starter #13
i want the wheels to mach up with the wheel wells or stick out just a bit. i do not want to waist my time with 5mm if that is not going to cut it
1 - 13 of 13 Posts
