1 - 10 of 10 Posts
It would be very helpful if someone could explain or give me a link that explains the easiest method to get to the radio serial number. I need to get that number since I dont have the the radio code and plan on disconecting the battery this weekend.
Thanks much
Chad
Easy, take it to your nearst dealer and ask them to get the code for you. If they tell you some BS about a charge, show them in your audio system owners manual where it says this service will be provided at no charge for a long as that car (whether you're the original owner or not) is on the road.
Paul :thumbup:
Will the code need to be reprogramed into the head unit if I disconnect the battery? Or does the code only need to be used if the head unit is actually disconnected at the wiring harness. The reason i ask is because i will be disconnecting the battery soon whenever i install an aftermarket amplifier.
Thanks
Paul
It has been my experience if the headunit is going back in the car in originally came out of the code does not need to be entered, I have also seen where the code did not need to entered after loss of battery power at least on 2000 and up cars.
Pete
Every, and I mean EVERY VW coded radio I've seen, even the newer ones needed to have the code entered after battery power was lost. Worst case is he lucks out and doesn't need it now, but it's nice to have if he ever does.
Paul :thumbup:
Same happened with my gamma radio, I took it out of the car and put it back in. The display said "SAFTEY" for a few secs and then it was fine. No code needed.
Dan
The radio code for your stereo can be found on a sticker affixed to the wheel well of your spare tire in your trunk.
HTHs!
Bmpassat said:
Paul
Pete
I didn't disconnect battery power, but when I removed my head unit from my 2004 for about 4hrs (when installing my ipod), I didn't need my code when I plugged it back in.
Your iPod installation
gig103 said:
Bmpassat said:
Paul
Pete
gig103,
Nice iPod install!
I see that you used the Sik Imp while the electrically similar install at
http://www.grazethepavement.net/Westy/ipod.htm
used the Belkin. The Belkin lets you adjust the output volume, and also offers a true "one wire" connection; but the sound quality may not be as good (I suppose one could take the Belkin apart and use the inputs to the amp, instead of the outputs).
So -- do you find the volume OK? That is, does it match the general volume of the radio and/or CD? If they don't match, I can imagine overly loud sound when changing in one direction or the other.
And why did you choose the Sik over the Belkin?
Thanks.
1 - 10 of 10 Posts
