1 - 7 of 7 Posts
needs more cowbell
i went with 17s from my 15 inch steelies. rode all last summer/fall and until first snow (litterally). they don't look too awful and the lower tire profile was incredible difference.
1 vote for 17s
if you click on website below...you can see my car with the 17s and no drop. not awful and handled worlds different
Technically your car will look like an SUV with any size wheel without a drop on it. The wheel/tire outside diameter is still the same with 15's or 18's so you won't avoid the SUV look with whatever you get.
Dont spend money of aftermarket 16's, if is between thoose 2 definately go 17's. Personaly even 17's are to small for me.
Go big or go home :lol:
Just playing, my neighbor had 17's on his B5.5 with stock suspension and it didnt look that SUVish, but it was riding a little high :crazy:
I'd try to go with the widest tire possible without rubbing, and something that's as light as possible. That being said, I don't think there's a lot of light 15's and 16's around. If you're a real baller, and have the patience, you might want to call up a local Volk/Rays Engineering dealer, and see if they can order a superlight forged TE-37, CE-28, or SE-37 wheel in 15x8, or 16x8 in a custom 5x112 (or was it 113) bolt pattern for the Passat. I have a set of 15x7 TE's that weight 9.2 lbs per wheel. You can also prob get a custom color. It should cost around $1,600+ for the 15's though, and most likely there is a 6 month wait. I'm not 100% sure if you can get a custom bolt pattern though, but I've heard it's been done before.
Otherwise, if you must go 17's, get the semi-forged 17x8.5 SSR Competitions. They're 15 lbs ea, and are pretty reasonably priced for what you get.
1 - 7 of 7 Posts
