1 - 20 of 40 Posts
I went to the track today for the first time.. only did one pass .. my time was 17.1 @ 83mph with a 2.8 60'
My car is a '98 1.8T 5Speed...100% Stock.
Do you guys think I can hit mid 16's with a lower 60'?
What are your guys times??
i believe stock its supposed to be around 16.3 or 16.4 so yea....
15.1 with exhaust...intake..bov...and chip....since then i gotten a DP and high flow cat..so i should be in the high 14's....just make sure you dont put on 18's when doing the 1/4 slow you down a lil bit :wink:
Running stock i was only able to pull a 17 second quarter mile with a five speed that was a few years ago though and i had no prior experience at the drag. 16 are still pretty hard to pull with a stock car. You will really have to beat on your car to run 16 seconds. (stock)
sebaflex a year ago I hit [email protected] at salinas speedway and have a passat 1.8t tiptronic with go fast bits just make sure you use a small diameter wheel like 15 or 16 in. :thumbup: and if it is a tiptronic make sure to powerbrake so you can jump away when the chrismas tree lights up
ran car a few times avg time 1/4 - 16.2 to 16.5 seconds
completely stock 2001.5 GLX 30V, V6 with tip , the better times i got was running with out fooling with the tip gate. wheels running stock 16 inch factory
I've ran with a 15.9 at 92mph completely stock accept for the 18's. then I ran a 15.7 at 93mph with my brand new Ghetto-fabrications intake and From-da-hood custom design exhaust. Oh, cars a 01 V6 tip. When I stripped my interior and shed the 18's I ran a 15.3 at 95.........only got that once, the rest were a little slower.
Mine did it in slow. I think slow is a time but I am not sure if it is a number. Yep, just plane S-L-O-W. :sad:
Stock '99 1.8T with 182Kmiles
i ran 18.042 @ 79.456 miles an hour!! :weirdo:
I have 17" wheels, and an intake and exhuast!!!
The track i ran at went kind of up hill!! I think that sloawed me down some!!!
Hope to better with some more mods!! :lol: :lol:
I did 10.4 @ 136 with a 1.5 60ft in my 1998 Z28 on 10 inch ET streets, engine was a LS1, with JE pistons, spider aluminum manifold, ARE stage 3 heads, LG G5 cam, NX dual stage wet 200 shot on a moser rear end with 3:42 gears, and I was spinning the tires down the track
went 12.4 @ 118 in my 1993 DSM AWD on a big 16G with spearco FMIC running 23 psi on VP Blue gas
Ran 10.4 @ 134 on my 2000 R1
Don't even want to take my Passat to the track.
UK Spec W8 Tiptronic - completely stock with standard octane fuel (half a tank at the time of the runs) 17" Madras wheels, spare wheel etc in trunk (i.e. nothing stripped out to lighten it)
16.072 at 85.53mph
Next time will lighten the car and run higher octane - hope to get somewhere in the 15s...or better if I get it chipped first...
my goal is 15 flat after chip,forge dv and exhaust.
I DID A G- TECH RUN THIS MORNING
using the weight as = 4,372lbs (had my brother with me he's 120ish)
use = 4,250lbs w full spare
And did the Qt= 16. @ 94.4mph good launch
again = 16.12 @ 92.14mph
as for The Horses= 235 :roll: i might have weight wrong
but i was like :shock: dammmmmm
pulley, intake, 2.5 dp, bov, bv, chip
1 - 20 of 40 Posts
