1 - 15 of 15 Posts
Is there any special lubricant that is recommended for the door hinges? Also, the hood air prop shaft is getting noisey. Thanks
White Lube = Lithium grease. It is available just about everywhere... Wal-Mart, any auto parts store, etc. It comes in sqeeze tubes, aerosol cans, etc.
SirWired
White lithuim grease is one of the more common lubes. Spray or tube. It lasts about a year. There is also a lube that VW uses, it was posted a few days ago, not sure of the name.
I've used lithium grease (white lube) and have recently used penetrating oil after the lithium grease.
I'm using Einszett Ultra Gel.
Excerpt from their website (http://www.1z-usa.com/sys-tmpl/lubricants/) :
When you need a true lubricant, Ultra Gel is a superior synthetic spray grease formulated for the most demanding, high speed, heavy loaded applications. Formulated with Shell® brand AeroShell® Grease 22*, Ultral Gel reduces friction for maximized power output. Wide temperature range from -40°C to +220°C (-40oF to +430oF), resin and acid-free. Turns from a deep penetrating liquid to a long-lasting durable semi-solid lubricant in seconds. Contains active corrosion protection with excellent adhesion. Ultra Gel will not sling, collect dust, and is water resistant. Contains active O-Ring protection for proper maintenance of motorcycle sprockets and chains. Also for use on brake shafts, springs, universal joints, hinges, wheel, ATV's, go-karts, and clutch bearings or wherever high stress points require lubrication. Classified with Military Spec designation (Mil-G-81322 F)*.
Sounds alot like the Wurth product.
Yup, I have high speed, high temp door hinges. lol. ;)
I had a squeak coming from my driver's door hinge, so I tried lithium grease from a tub, but it didn't penetrate. Perhaps a lithium grease spray would work better. In any event, I then tried a fairly heavy bicycle lube (Phil Wood) and it did the job instantly.
I use spray white lithium grease, but it only lasts about 6 months. Still better than dealing with the damned check straps on BMWs and their underengineered doors.
1 - 15 of 15 Posts
