41 - 60 of 69 Posts
i got mine last october.
it looked like this the day i bought her...
10 months later i'm here... (took these today)
along the way, i've done the entire front suspension, timing belt, ect. still need motor mounts.
So far this summer as of June...
sold old car to my sister
got a loan
cashed bonds
bought it
took it home
DARE plated it
took off all dealer tags
new headlight bulbs
cut antenna
ASS badge on trunk
Alpine 9885 headunit
subaru impreza 2.5 floor mats
OEM floor mats
audi RS4 eight spoke replicas
kumho 235/40/18x8.5 summer tires
'02 GLS
I've owned it for 11 months now.
*K&N panel filter
*replaced two inline check valves
*APR 93 octane DPP
*found and fixed vacuum leak (L hose)
*Got the STOP low oil pressure warning, and have been saving up money for a new engine for the past 9 1/2 months. Should get car back next thursday.
Discussion Starter #46
I know I'll be getting a passat wagon within the next few months and I am just trying to decide on what i should be hunting for 1.8t or 2.8 vr6; 5spd or tip? any input on maintenance as this will likely be the determining factor.
thanks.
Most here would say the V6 is more reliable, but both engines have their drawbacks. A used 1.8T is risky unless you know the maintenance history - synthetic oil only at the proper OCI. Otherwise, it could have a sludge problem. See a post or two above on that (STOP light on low oil pressure). BTW, the Passat has a V6, not the same as VW's vr6.
I have managed to completely rip the whole car apart.
Spent an ass load of money on it and have done absolutely nothing about getting it back together. I should probably be punished in some way. Like sentenced to the garage and don't come out until it's done.
What time is Matlock on?
Hmmmmm....this year alone?
Koni (yellow) shocks
Neuspeed springs
17" S4 Avus wheels with Kumho ASX tires
W8 Bi-xenon lights
EVOMS intake, and back to stock
Darker bumper lights
Professionally painted engine bay parts
New car battery
Fresh respray of hood, l/r front quarterpanels, roof
Kamei sport grill
Stubby side-view mirrors
CA reset
Both axles replaced up front
W8 belly pan
Huh....I guess that's it......oh wait.....
FMIC and DV coming up within the next month :)
U guys are mod mad I tell ya! But that is good!
I'm outta warranty with my 1.8T '03 B5 so will probably start doing some more mods. (zerolux, feel free to come over and work on mine anytime!)
Only thing so far this year is a new set of rims and tires. Conservative 16" MSW Type 15 (shipping in Sept) with Kumho Ecsta SPT rubber from the tire rack. Am thinking about chipping and getting a new stereo. Any recommendations?
Any chip upgrades allow ya to keep using 87 octane?
So far:
changed oil and filter
replaced broken timing belt tensioner so while I was down there...
replaced all belts
replaced water pump
replaced coolant
replaced broken dip-stick tube's plastic section
replaced leaking oil pressure (idiot light) switch
replaced coolant temp. sensor that nearly stranded me a couple of times.
Also replaced all 4 tires. I may make it to the end of the year before my Die-Hard really dies-hard! It's getting harder to start these days; my last one went for 5 years. This one is over 4 years so it may be time. :D
99 Passat
Had the Timing belt, water pump, tensioner and everything in between changed
APR Chip
42DD boost gauge
Sirius Radio Integration
Changed both Tie-Rod Ends
Closed the garage door on rear bumper :hmmm:
Won't somebody please rear end me so I can get rid of this train wreck of a rear bumper.
You're not suppose to use 87 Octane to begin with
oh.... not too much:
badgeless front grille
new cd player
chipped
HID
Eminence lab 12 in 3 cu ft box tuned to 24 hz ( best sub i have heard in price range and i have built many subs for ppl at my school)
on that note 150 amp alternator
debadged yesterday ( it was an ass for a few hours)
Plans:
go to college
graduate with a EE degree
Other mods:
if only I had any money left:cry: :cry:
k&n air filter, koni sport shocks, 13% tints in back, 35% tints in front, 1BE springs, 1BE swaybar, 17" asa AR2s, 235/45/17 ContiExtremeContact, Chrysler pacifica shortened antenna, m3 lip spoiler, new fuel filter, new spark plugs, soon to have a chip but not decided on which one
This year:
Added Integrated Hands-Free Bluetooth system.
New Tires (MICHELIN Pilot Exalto A/S).
New Trunk Struts.
New Window regulator.
Routine Maint. (Bulbs, oil changes, filter changes, etc...)
Lefties have rights, too!
This year.
  1. Installed Skoda air vents
  2. Installed Westfalia tow bar
  3. Installed MDF2 RNS DVD navi
Still want to do rear fog mod.
This thread made me think that I've done more to it than I originally thought.
Changed sythetic oil
changed sythetic oil
changed sythetic oil 1000k too late
Added a direct power line to the radar detector
Got in an accident and had the hood and passenger side resprayed
New bumper
New orange corners
New tires on my Audi sports
New window regulator
Used lock cylinder
New fuse #14
Found change under the seat and bought a Dr. Pepper
and a couple of car washes with fancy wheel treatment stuff by McGuires
Since I bought the car used in April:
Oil Change/Air & Cabin Filter
Oil Dipstick Tube
Timing Belt and all other Belts
Spark Plugs
Tensioner
Water Pump
Coolan Flush
Coolant Bottle
Fuel Filter
Valve Cover Gasket
Febi Control Arm Kit (All)
Front Pads
Front Wheels Bearings
Outer CV Boots
New Tires
KW Coilovers
41 - 60 of 69 Posts
