1 - 7 of 7 Posts
Here is what the Vag I just built pulled from my car, can anyone tell me what is going on? TIA.
Address 01
Controller: 4B0 906 018 BH
Component: 1.8L R4/5VT G 0006
Coding: 07551
Shop #: WSC 00028
1 Faults Found:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Readiness: 0010 1101
Address 02
Controller: 8D0 927 156 AN
Component: AG5 01V 1.8l5VT USA 3132
Coding: 00104
Shop #: WSC 00028
1 Faults Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 46
Controller: 1J0 959 799 AJ
Component: 6W Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00028
2 Faults Found:
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
Well... from the looks of it, your engine is running too lean (too much air, not enough fuel), you are having some type of error with the ECU (no idea what), and both your heated mirrors are burnt out (kinda expensive... I take it you leave your mirrors in the center setting rather than set to R or L)
No I dont ever use them... I just forget that the mirrors are heated, well i guess there is not need to try it now.
Well, a common error is to place the selector for the power mirrors in the center switch position rather than on R or L, this can cause premature failure of the heater element due to overuse.
I pulled the same code about the mirrors, I left mine on the center switch position for about a year before i realized it probably wasn't a good idea...now the heating elements don't work :sad:
1 - 7 of 7 Posts
