What did you do to your Passat today?
1350541 Views 11609 Replies 1401 Participants Last post by  Iowegian
I've seen this on many forums and it's always been a winner. Post up what you did to your car today. Add a picture or two that show what your did.
With that, I give you my addition, I polished my headlights.
Automotive parking light Car Vehicle Vehicle registration plate Grille
Reactions: 5
11521 - 11540 of 11610 Posts
If you're talking about the hard plastic elbow that attaches to the throttle body, that bolt is actually a 5mm allen head. A mini ratchet and magnetic bit holder is what I use to get at that little bastard.
If you have a socket wrench extended Allen key, that will work with a 3/8 driver - just to get it loose. Then you’ll need to switch to a stubby to get it out as you’ll back into the firewall. Remove sensors from the snorkel first! Ask me how I know…
Reactions: 2
Fit some new Audi Sport 17s on it!
I like the look, they’re just heavy wheels; lost about 3mpg over 300mi drive, and quite a bit of acceleration lost vs the stock 15s which were 10lbs lighter per wheel!
Automotive parking light Wheel Tire Cloud Sky
  • Wow
Reactions: 4
Got it off and see no signs of leaking, so the search continues. Anything I should do before I put it back together?
Motor vehicle Automotive tire Automotive design Automotive exterior Gas
Reactions: 1
Coolant leaks? That back water pipe that the temp sensor plugs into: are the ends that seat against the block dry? Slightly towards the bank 2 side, is the water pipe coming out from under the intake manifold dry? (Check the front end of that on the right side and under the ignition coil. Check the front and rear bleeder screws. Check the two heater core hoses connecting under the back black pipe. Also check the valley under the intake manifold. Under the intake manifold there are two coolant hoses for the throttle body; engine heat will dry those out too. There’s more at the front to check as well.
You’re not just looking for wetness. A hot engine evaporates most of it. Look for dry white/pink scale build up.
Reactions: 2
Just today, I spent quite a significant amount of time working on my Passat 2017. First and foremost, I gave it a thorough wash, ensuring every nook and cranny was free of dirt and grime. Next, I inspected the tires and checked their pressure – adjusting it as needed for optimal performance. I bought it via A Better Bid, a car auction in Houston several months ago so I believe that it is still much too early for me to spend any considerable amount of money on its maintainance because still the car rides really well (y)
Put it back together today. Thanks to Rob’s detailed response I searched everywhere on the left side. Looked over and saw coolant on the hose clamp below the upper radiator hose. Looks like I need a new hose. It was wet underneath the joint.
Automotive tire Motor vehicle Automotive fuel system Gas Auto part
Motor vehicle Automotive tire Automotive exterior Rim Gas
Reactions: 1
Just today, I spent quite a significant amount of time working on my Passat 2017. First and foremost, I gave it a thorough wash, ensuring every nook and cranny was free of dirt and grime. Next, I inspected the tires and checked their pressure – adjusting it as needed for optimal performance. I bought it via a car auction in Houston several months ago so I believe that it is still much too early for me to spend any considerable amount of money on its maintainance because still the car rides really well (y)
Your account says you are from Ireland. You shipped it from Houston to there? Also, this is the B5 Passat thread. We also have one for B7s which is what the 2017 model is.
Reactions: 1
I was wondering the same thing but declined to comment.
Maybe some IP masking / spoofing going on here.
You might only need to get rid of that hose clamp and go back to one of the original spring-type. Those worm-gears suck !
Reactions: 1
It's not leaking from the lower. I put that on after the lower popped off on the way home after buying it.
New wheels and a nuerotic cleaning 😁
  • Wow
Reactions: 5
You know... for not being a B5.5 4Mo Wagon, it looks ok!
Seriously good looking, man
Reactions: 1
So I know it's not today, and it's not even my car.... But Sunday I was in Phoenix and took a drive it to go meet another member on here. Drive out to meet AndreasPassat, Dave, and got to see his Passat fleet. It was a great time, I'm always glad to meet people with common interests, and oogle at his cars. Which by the way, the black on black W8 was great looking. 👌
And I might try and talk him out of the Pacific blue w8.... 🤔
  • Haha
Reactions: 4
Thanks man!! Appreciate that!
My other one got a bath as well lol
Reactions: 2
Seeing as it's a sedan, it looks awesome!
Fixed it for ya Rob. :p
  • Haha
Reactions: 2
Soon as the clutch and the clunking front end are taken care of, It's all yours.
Reactions: 2
Hell, I'd take it as is.
Today in going to change a coil pack on my v6 car and see if the misfire goes away. I also need to dig into my poor W8 sedan and find out why my driver head light won't stay on.
Working on the vacuum hoses. Bought 3.5mm silicone hose, a bunch of connectors, 8mm hose clamps, and 12mm hose clamps.
Reactions: 1
Searching for an auto trans that's fwd for a 1.8t at a junk yard, and happened across this.
Automotive tail & brake light Vehicle Car Sky Automotive lighting
Can't say just how much I would have loved to get my hands on this before it ended up here. It was only the V8, otherwise I'd be coming home with a W12.... Can these front seats possibly fit in a B5.5 you think? I mean massaging seats do sound really nice.
Reactions: 3
Where there's a will, there's a way.
Reactions: 3
