New wheel hubs and engine mounts are installed and I took it out for a drive. The Good: it is shifting, driving and braking great! It rolls so much quieter with the new rear wheel bearings, and the engine vibration is so much better with the new mounts.
Here is a pic of the new mount vs. the removed mounts...
The Bad: an ABS code is being thrown for the RR wheel speed sensor. My guess is that I damaged it during the removal because of all the corrosion. Also, I was going to replace the valve cover gaskets (I still will), but in the process of taking the plastic covers off of the engine, I noticed that the accessory drive belt is torn!
This was a Contitech belt (part of an ADK0048P kit I installed about 50k miles ago) that has a tear in it now. So, I need to order that, as well. Any recommendations? I would replace the belt and tensioner - any recommendations on a brand? Do I go with a Gates or Dayco kit this time around, or stick with Conti again?
And, while I'm at it I might as well order the O2 sensors and get rid of the ECU codes (I think I fried the 2 on the cats when I had to remove them to install the latest replacement flex joints).
