10001 - 10020 of 10038 Posts
Yes, but have you read every one of those 10K ? And yes, I expect I probably did read them all.
o_O
o_O
Not even close. Probably haven't read 90% of them
Reactions: Rob.Achmann
What I did today was order a set of new o-rings for the injectors. Fired her up to circulate the oil and keep the battery charged when I noticed the distinct smell of raw fuel. Noticed that the leak was coming from the passenger side rail/injectors area to the point of pooling around each one where they enter the manifold. Probably leaking just due to this cold weather. If the forecast cooperates, these o-rings should arrive to coincide when the temps finally climbs into the 20s which will make this repair tolerable.
I am a compulsive reader, I used to read a lot of books, but the internet has replaced that. At least I have been able to control the compulsive eating that I used to do when I was younger.
Opposite of me. I only read what I absolutely have to. I have only ever officially read two books in my life.
Runaway Ralph by Beverley Clearly and Alive by Piers Paul Read.
There's a name for what defect I have, can't remember what it's called though.
When I read I have to go back and re-read portions of sentences. Although I know what the words mean, it doesn't compute as I'm reading. What people normally read in let's say five minutes takes me about 3 times as long.
And then afterwards I don't retain much of what I've just read. It's very frustrating.
For me to read anything it has to something I am very interested in, and at that, I just read the high points and then move on.
You sound like most of my clients that read my emails, lol. I swear, none of them actually read anything and then bitch about not knowing about a date or spec when it was all right there.
Is it easy to do? I'm seeing raw fuel spray too and the injectors seem very loose. Is there a procedure?
This reads easy enough; unplug the electrical connections and remove the fuel rail and injectors as one unit, then tackle the injectors one at a time. If yours are truly that loose, then maybe they came unseated. Try pushing each one down - if they move, you have serious problems. Mine just had fuel vapors rising up thru the engine cover that got my attention.
What I did to pinpoint that it was the lower o-rings that were the problem was I squirted some engine oil around the base where they enter the intake manifold. That got rid of my leak temporarily until the new o-rings arrive.
Good luck with yours.
Got a dash light on my fuel cap. Not a surprise for aHave to get a new one. But omg, where am I going to find one that big!?!? (Matching Code for very small vacuum leak. But that could be from my hack job of a replacement for the ones between my combi valves
I thought that was the seat eject code 😂
Doing the fuel injectors today. I thought I might have been sent the wrong o-rings; the new ones look nothing like the originals. Nope, the originals are just that worn or mis-shapened. I should have known by how loose they were seated in the fuel rail.
102406
102407
102408
Doing the fuel injectors today. I thought I might have been sent the wrong o-rings; the new ones look nothing like the originals. Nope, the originals are just that worn or mis-shapened. I should have known by how loose they were seated in the fuel rail. View attachment 102406 View attachment 102407 View attachment 102408
So, you need 12 o-rings for the 6 injectors, right? For top & bottom on each? Should you also replace the ‘safety clip’ for each as well? They are part # 077 906 037 A
Yep, for the 2.8 you need 12 total. I didn't buy new clips - mine were still in good shape.
Question for anyone who has done this - how the Hell do you get those little filter baskets out ?
<edit> #8 x 1 1/2" wood screw did the trick.
Replaced both the engine and transmission mounts in my ‘03 V6, not hard but tight space
Sent from my iPad using Tapatalk
I hate changing the driver's side on the V6. No room to work, I bought a 13mm stubby ratcheting wrench just for that.
What? What filter basket? You used a wood screw??
