1 - 14 of 14 Posts
I've got a 2000 Passat 4cyl turbo w/ Tip @80K and I've got a really, really bad problem w/ the accelleration. If I hit the gas I have to hit it slowly for if I do it too fast it sputters. It's reaaaaly touchy. It mostly does it when it's under load and I try to accellerate.
I'm between jobs and I can't afford to take it into the shop right now. I was wondering if any of you have experienced this? I'm thinking it could be the timing belt? To my knowledge I don't think they replaced it at my 60K tune-up.
Thanks, folks.
have you taken a look at your throttle body? I cleaned mine out last year because of a bouncing idle and a few stalls at startup. Once I cleaned it, all normal again. You can pick up some 3M throttle plate cleaner for under 5 bucks.
Sounds about right
Thanks for the reply! Yeah, I've experienced some of the same things w/ the startup and stalling as well.
I really have the same question when it comes to the procedure to do this. Does the product you mention explain this at all? Or can I get a Chilton (or equivalent) to explain the process?
Thanks again.
Shawn
The Bentley manual does not provide a method for cleaning the throttle body. I read in another thread that carb. cleaner is what to use.
Also check your spark plugs. I had this same problem resolved about a month ago. The dealer actually gave me that advice and it worked. Who would have thought? Good Luck.
Once again, thanks for the help, folks.
I'm a little vague on the procedure for cleaning the throttle body, but wish me luck.
Hey, do any of you know about how to replace the bulb in the thermostat control? I can't figure out how to get the trim plate off. :mad: ...and, I don't want to break it, like I did on an old car.
Thanks!
coil pack.
could be a misfire instead of throttle body.
...especially if your car feels like you're accelerating on a cobblestone road when you hit the gas.
-Harry :beer:
FWIW, I have gotten misfires due to throttle body malfunction. :)
jackman, is it a rotary dial climate control or the digital Climatronic?
I had the same problem too! I replaced the Sparkies and I was running smooth again. :)
1 - 14 of 14 Posts
